Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > V10 Specific Topics
ZDOG
Old 02-17-2011, 03:22 PM
christheduallyman christheduallyman is offline
Vehicle: 2002 dodge ram 3500
Trim Level: SLT Laramie
Color: blue pearlcoat
Engine: 2003-2003 488ci (8.0L) Magnum V10 310hp 450lb/ft
christheduallyman is on a distinguished road
Default Engine vibration help
Hey guys I have a 2002 3500 dually 2wd v10 with 32,000 miles that i just bought. When it idles there is a pretty good vibration going on. It clears out when accelerating, but when sitting idling it's almost like a buzzing. Runs great other than that. Any suggestions on what it might be? THanks
Old 02-18-2011, 01:16 AM
switchfoot2's Avatar
switchfoot2 switchfoot2 is offline
Vehicle: 1994 Dodge Ram 2500
Color: Emerald Green
switchfoot2 is on a distinguished road
It depends on what kind of vibration you're talking about. A buzz could be a loose exhaust manifold cover or it could be a misfire. The vibration goes a way most likely because the rpms change from idle, which is just enough to get something vibrating. Most likely it's just something loose under the hood. I've only ever had buzz noises because of a loose exhaust manifold cover. Hope that helps!
Intake Belly Pan Gasket RamTech Dodge Ram Knowledge Base 3 02-27-2015 03:30 PM
engine swap 02 4.7 for 05 4.7 JoeBoss Newbie Checkin! 8 11-18-2010 01:13 AM
Truck shaking when gas is depressed dirtsurferus 5.9L V8 Specific Topics 12 01-31-2010 02:19 PM
Painting Engine Cover Incognito Dodge Ram General Discussion 15 01-11-2010 11:14 AM
What kind of gas do you use?????? bransonshemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 61 12-08-2009 10:38 PM
