Old 02-17-2011, 05:33 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Default Front axle track bar 06 1500 sport
Where is the dang track bar on this model?
I can't seem to find the dang bar. Does my truck even have one? Its the 06 ram 1500 with electronic 4 wheel drive changer. The front end looks really different then other trucks front ends. Like its not a solid axle in the front. The front differential is all up inside the bottom of the truck almost.
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 02-17-2011, 05:35 PM
Resident Technician
Rep:1915
Track bars are installed on solid front axles with coil spring suspensions.
Old 02-17-2011, 05:43 PM
sullivan's Avatar
Rep:202
Ahh, so what does this mean for me. What type of front end would you call mine? Instead of single-axle.
And right now, I feel I have a somewhat bumpy cab ride, i have gotten new tires, new tie rod ends, inspected inner tie rods, 2 alignments, balance on new tires, I thought maybe checking out the track bar would be the next thing. Whats next? I am thinking maybe all new shocks would possibly fix it, but would bad bushings or anything cause this? I had firestone inspect my front end, they said all that was out was my out tie rods. So I fixed them and got new tires and all.
Old 02-17-2011, 05:56 PM
Resident Technician
Rep:1915
You have an independent front suspension. Bad suspension components are usually accompanied buy thunk and clunk type noises. How much air is in your tires?
Old 02-17-2011, 06:27 PM
sullivan's Avatar
Rep:202
Well I just bought new ones, the sheet from discount tire says the tire manufacture reqs. are 35psi, but the dude who drove it around to the front said "we put new chrome valve caps on and pressured it to 40psi and zeroed out everything".
Would that affect anything?
Maybe it's just me, and I am freaking out over a little bumpyness in my big truck.
What kind of front axle is on a 96 dodge 1500 4X4 Lionheart LD RAM - General Discussion 4 01-03-2013 08:00 PM
Snowplowing with my 1500 johnf15 2010 Dodge Ram Forum 7 11-29-2012 04:32 PM
Replacing the seals in the front axle spartydude Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 08-08-2009 02:01 PM
Front Axle swap and other info Crazy Canadian Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 06-12-2009 06:05 AM
2003 ram 1500 axle nut size?(NEWBIE) richmsgt Newbie Checkin! 1 06-02-2009 03:41 PM
