Old 02-17-2011, 05:36 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
Default anybody ever do a street cam?
me and the brother are thinkin about putting a cam in his 5.9 when we fix the knock in the engine or get a new engine to work with i was wondering if anyone on here has ever done mild street cams with their 5.9's. if so what size, brand and where did you get it and if its worth doing. and if you do this what other parts you need to have this mild cam to make it run right, like bigger injectors or pcm flashes or something, i know you usually need stronger valve springs and different length pushrods. also is there kits you can buy to get everything you need for it. were gonna do it pretty soon so any info ASAP.
thank guys
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 02-17-2011, 06:02 PM
Rep:1909
Depends on what you call miled, I guess. If you're looking at what's generally referred to as an "RV" cam that's meant to make low range torque and pulling power, then the stock setup will work with a mild tune at most. What I call a street cam would need bigger injectors, a throttle body, headers, stall converter and a custom tune.
Old 02-17-2011, 06:11 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
You're best bet is to do what randy said as his idea of a street cam lol. Cause you'll get used to the power and want more after a week.
Old 02-17-2011, 07:22 PM
98redbull2's Avatar
Rep:52
haha well all we want is just a little more power than stock. its probably never coming apart after it gets put toghether, we dont have alot of money. can we get away with putting a small cam in it (bigger than stock) not aggressive but you know what i mean with just the stiffer springs and right size pushrods and new lifters? i feel bad for my brother im trying to do as much as i can for em cuz were just turning 18 and we dont have alot of money and his trucks been sittin for about a week now lol. so cheepest way even if its not VERY cheap dont have to make a ton of power, hes been wantin to do this for a while. do u think we could get away with it?
Old 02-17-2011, 07:25 PM
Rep:1909
An "RV" cam can typically be used with stock springs and stock length pushrods negating the expense of these parts.
Old 02-17-2011, 07:28 PM
98redbull2's Avatar
Rep:52
so how much bigger is the rv cam? is it just barelly a difference? just the low end torque?
Old 02-17-2011, 07:34 PM
Rep:1909
RV cams generally make power from off idle up to about 4500 rpm which is what you want for a truck, especially if does much towing or hauling. The entire cam profile is what makes it work, not just lift. If you just want more life, you can increase the rocker arm ratio and do that but your duration and overlap will remain the same.
Old 02-17-2011, 07:40 PM
98redbull2's Avatar
Rep:52
allright cool so do you know of any power gains with the 5.9's with these cams?
and you dont have to do bigger injectors and stuff like that?
and ive been lookin around a bit for the cams for the magnum engines i cant really find much do you know of any good websites?
Old 02-17-2011, 07:42 PM
Rep:1909
I don't have actual dyno numbers for a projected gain. For info like that and help picking a cam that will do what you want, you really should call someone like Summit, Jegs, Doug Herbert, or the cam company of the brand you prefer.
Old 02-17-2011, 07:48 PM
98redbull2's Avatar
Rep:52
ok i guess ill start doin some research
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
Cam support questions moparmike07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 23 01-19-2011 12:17 PM
Got my diablo, doing cam soon have questions MoparerNocar Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 4 08-07-2010 05:21 PM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 03:01 PM
Cam Question walightner Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 05-13-2010 09:43 AM
