Old 02-17-2011, 09:49 PM
MaddogGM MaddogGM is offline
Vehicle: 1997 Dodge Ram 1500
MaddogGM is on a distinguished road
Default Front Axel U-Joints
I want to start out to say that I know nothing about 4x4 suspensions on a Dodge. I am very mechanical I worked on a road racing team for three years and have played around with cars since I was 6 years old. Just never worked on anything 4 wheel drive. I have a 97 1500 RAM 4x4 that I inherited and it is in need of some repairs. The right front axel u-joints are shot and need to be replaced. I need to know how to do this. I have looked in my repair manual and it seems to just skip right over it. Somehow I am guessing it is not as easy as replacing a u-joint on a driveshaft. Thanks for the help.
Old 02-18-2011, 09:09 AM
Rep:1885
You need to remove the caliper, rotor and hub bearing (which I can about guarantee won't be easy; you may destroy the bearing in the process). Then just slide the axle out and replace the joint.
Old 02-24-2011, 11:37 PM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
The hub bearing is a pain to remove. The easiest way I have found was to back all three bolts holding the bearing in out about 1/4 inch. Then put a deep well socket on lower bolt holding the wheel bearing in and hold it there while someone turns the steering wheel jamming the socket between the bolt head and the inner C this in most cases will push the bearing out a quarter inch at a time. Most of the time you will have to start the truck to use the power steering to get enough power to do it. When you go to take the nut off the end of the axle shaft you may need a 6 foot long piece of pipe on the end of the breaker bar. The socket size is 36mm IIRC. There are several youtube videos on this. Them guys hammer the bearing out but this can cause more damage then good.
Old 05-01-2011, 10:04 AM
zxbud zxbud is offline
Vehicle: 1999 Dodge Raam 4x4
Rep:13
zxbud is on a distinguished road
I just did this to both sides at once. I used pb blaster first and then removed the hubs with axels attatched as there's no reason to separate them if the bearings are good. Used a ball joint press from Autozone which will work on ujoints, too. I could not hammer the old joints out. Had to used a 500 lb ft air ratchet on the press to get the 4 hour job done. Truck has 190000 miles and is a 1999 1500.
front end, u-joint
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
Death wobble = axle swap fundaddy75 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 11-08-2010 10:50 PM
Front Ball Joints - When to Replace? Jon89 Suspension 1 10-19-2010 08:22 PM
04 dodge ram front differential noise timhorton Newbie Checkin! 10 09-24-2010 10:48 PM
replace front axel universal mordodge Newbie Checkin! 12 09-16-2010 06:35 PM
