Uneven tire wear on front outer tires - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-17-2011, 11:29 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Default Uneven tire wear on front outer tires
My last set of tires had uneven tire wear on both sides, mostly due to not having the truck aligned and tires not being rotated.
But would any suspension issue cause this wear on the tires such as bad ball joints?
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 02-17-2011, 11:33 PM
ScatPak07's Avatar
Rep:970
I would start off with the alignment and if that doesn't help then you should look into it. The shop that does the alignment should be able to tell you if there is something else that needs to be done
Old 02-17-2011, 11:45 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
What he said!
Old 02-20-2011, 11:16 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
One of my friends has a stock crew cap 09 and he has the same problem.The shop told him there is nothing they can do.I would be looking for another alignment shop.
Old 02-20-2011, 12:49 PM
Most good front end alignment guys check the front end over and air up the tires first before doing a alignment .
Old 02-22-2011, 12:13 PM
sullivan's Avatar
Rep:202
I think since this is my first vehicle of my own and stuff, I am learning new things. Pretty sure the outer wear is from turning, nothing big. Just wanted my tires to stay nice and sharp on the edges.
Thanks guys, this is why you rotate your tires occasionally.
Old 02-22-2011, 12:53 PM
Resident Technician
Rep:1915
Uneven wear on the outside edges is a sign of misalignment, either excessive positive camber, toe-in or both.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
2006 vibration 55mph rake1 Suspension 41 03-07-2014 08:52 PM
04 ram Hd 2500 what tire size with 2''kit front & rear? gear head Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 02-03-2012 11:08 AM
Tire pressure monitor 2010Ramowner 2010 Dodge Ram Forum 3 04-30-2010 12:41 PM
Calibrating for larger tire ... How is it done? Eng0270 Dodge Ram Wheels And Tires 4 04-28-2010 10:04 PM
