whining noise from engine - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 02-18-2011, 10:46 AM
Travis Travis is offline
Vehicle: 2014 Ram 2500
Trim Level: Outdoorsman
Travis is on a distinguished road
Default whining noise from engine
I have an 06 RAM, with the 5.7 hemi. The truck has a whininy noise coming from the front of the engine. Sounds like a power steering pump, but the pump has been replaced twice, along with the idler pulley and the tensioner pulley, but it still is making the same noise. It doesnt sound like it is coming from the alternator or the ac condensor. The dealer said that it could be the air pump. Anyone have any ideas? Any help would be great because this noise is driving me nuts.
Thanks,
Travis
Old 02-18-2011, 11:15 PM
Start the motor up and verify the noise is there . Now shut it off , unload the serpentine belt and remove the belt from one pulley so the belt doesn't turn anything . Now start the engine for a brief couple seconds and see if the noise is gone . If it is , you now know the noise is being produced from one of those accessories . If the noise is still there , you need to start looking elsewhere , like maybe a vaccuum leak etc....
Old 02-21-2011, 09:14 AM
texas05ram's Avatar
texas05ram texas05ram is offline
Vehicle: 2005 Dodge Ram 1500
Rep:20
texas05ram is on a distinguished road
I know you said it wasnt the idler pulley but i'd double check, i had a noice and everything looked fine and couldnt really pinpoint the sound. When i removed the belt the pulley had completely disentergrated down to the metal bearing. worth a shot. i also agree with tom, thats some good trouble shooting advice.
Old 02-21-2011, 02:57 PM
07ram1500hemi 07ram1500hemi is offline
07ram1500hemi is on a distinguished road
Travis - wow! it sounds like we're having the same problem, I didn't notice your post initially, but noticed it as soon as I posted
http://www.ramforumz.com/showthread.php?t=75027
I have no idea on this either, and its driving me crazy, but was actually thinking it might be power steering related (just based on where the noise is coming from)
Old 02-21-2011, 03:08 PM
Rep:2962
to locate the noise, buy a mechanics stethoscope or use something like a cut off broom handle, place one end against the places where you think the noise is coming from & the other end in your closed hand, with your thumb & index finger above the stick, then place your ear against your thumb for ear protection
this is a tool that was used by everyone to find out which tappets were making the clicking noise, the noise travels up the stick & you can plainly hear it
Old 02-21-2011, 05:40 PM
okay, but what about if it only happens when your driving, and going over a bumpy surface?
Old 02-21-2011, 05:50 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Tom has presented a great troubleshooting idea! How did you make out?
brad
Interested in one of my mods?
Old 02-21-2011, 11:31 PM
Kruzer Kruzer is offline
Vehicle: 2007 Ram 1500
Color: Inferno Red
Rep:36
Kruzer is on a distinguished road
Keep it simple, is the powersteering fluid at the proper level. If the system is low it will always have air in the fluid and will never stop whinning. As mentioned removing the serp belt will help to narrow down the cause and a stethoscope is your best friend for pinpointing the noise.
When I have a problem like yours, I remove the drive belt and spin each accessory by hand and check for any play or roughness. I also use the stethoscope on one that I feel is suspect while spinning by hand. Plus sometimes when you unload the tension of the belt you might see a pully actually drop slightly indicating a problem. Hope this helps and good luck with fixing your problem.
Old 02-22-2011, 08:34 PM
I haven't removed the belt from the engine yet, but the mechanic used a stethescope and said he thought it was the air pump. Right now the truck is under warranty so i am kind of inclined to let them replace as much as they want too. I checked the fluid level for the power steering, and it is at the full mark,
Old 07-11-2017, 02:12 PM
JPBird JPBird is offline
Vehicle: 2006 Dodge Ram 1500 5.7 4x4
Rep:36
JPBird is on a distinguished road
So any resolution to this? I have the same issue on my 06 Ram 1500 5.7.....the whining is in sync with the RPMs in park and in drive. I removed the serp belt and spin the alternator which sounded smooth, the tensioner pulley sound a tad worn but didn't seem like enough to be causing the dB of whining I'm hearing. I'm really not wanting to take this thing in to the local garage for them to start shotgunning parts at the expense of a mortgage payment. I have read the previous posts, so any new helpful info or updates would be greatly appreciated, thanks!
Ram 2500 with engine noise. Big Ed 2010 Dodge Ram Forum 10 08-04-2015 02:03 PM
4.7 engine noise tapping at startup jglu3 4.7L PowerTech V8 Specific Topics 25 05-01-2013 11:18 AM
Wierd engine / drive train noise Help?` live2ride 5.7L V8 Specific Topics 11 03-22-2011 03:58 PM
Wierd Thump noise and engine bogs down Lordgwydion24 5.7L V8 Specific Topics 1 02-14-2011 11:32 PM
4.7 in 02 with engine noise mrafindley 4.7L PowerTech V8 Specific Topics 0 02-26-2009 08:55 PM
