United Radio
Old 02-19-2011, 01:58 AM
fireshallfear's Avatar
fireshallfear fireshallfear is offline
Vehicle: 2009 Hemi Ram Big Horn
Trim Level: Hemi Big Horn
Color: Blue
fireshallfear is on a distinguished road
Default Air or Nitrogen?
When I bought my truck, the dealership filled the tires with nitrogen and told me that it was more stable and the pressure changed less with temperature changes. That being said, I have had my TPMS light come on about 2 weeks after I reset it, every time all winter long. Ive gone through the tires and have found no leaks, a friend of mine dismounted all the tires to check for alloy corrosion around the bead of the rims and found nothing. My question is, has anyone noticed a difference between air and nitrogen? Has anyone had the same problems I have? Is nitrogen worth the money?
Old 02-19-2011, 02:38 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
My HID kits mess with my TPMS, but I run nitrogen and hardly ever have to adjust tire pressure
Old 02-19-2011, 01:22 PM
kddsram kddsram is offline
Vehicle: 2009 Dodge Ram Sport QC
kddsram is on a distinguished road
I use good ol fashion free air and never had a TPMS light come on. Tires are rotated every 10k miles and check pressure at that time but they are usually ok or close.
Superchips 93 octane|5% tm|custom trans shift schedule|MDS disabled|AFE Stage II|Magnaflow|3.92
Old 02-19-2011, 02:01 PM
SslagleZ28's Avatar
SslagleZ28 SslagleZ28 is offline
Vehicle: 2002 Dodge Ram
Rep:158
SslagleZ28 has a spectacular aura aboutSslagleZ28 has a spectacular aura about
I use nitrogen as well but I'm pretty sure i don't have TPMS
Backlash
Semper FI
Old 02-19-2011, 02:40 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
I run Nitrogen in my Super Bee and finally had to add some after 2 years of driving and sitting in storage each winter. Went back to were I had it done and they added at no charge so can't complain.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 02-19-2011, 03:47 PM
I push the skinny pedal
Rep:3277
I haven't found a benefit to the nitrogen over the air. Yes, the nitrogen doesn't contract as much as standard air in the cold, but the cost just doesn't work for me.
Kurtis
Old 02-19-2011, 07:34 PM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
Read some articles about nitrogen vs air. Nitrogen molecules are larger than air molecules so they cannot seep through the tire as easily as air, when it is cold the nitrogen molecules do not shrink as much as air, so little or no pressure loss over time. Also nitrogen is lighter than air allowing for better fuel mileage(supposedly). In warm climates the difference between cold tire pressure and warm tire pressure is mostly the same. In colder climates (using air) the difference between warm tire pressure and cold tire pressure can be 2 or 3 pounds. Now here in Halifax Nova Scotia I am charged $20.00 per tire per fill up of for nitrogen and air is free, some stations charge .50 and the money goes to some type of charity. If you don't mind checking your tire pressure once a week or so in the winter (if you have cold temps in the winter )then air is fine, if your service station allows for free or cheap nitrogen refills , for me air.
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors.
Future Mods: What ever I can sneak by my wife.
Old 02-20-2011, 09:09 AM
09bighorn's Avatar
09bighorn 09bighorn is offline
Vehicle: 2009 Dodge Ram Quad Cab
Trim Level: SLT Bighorn
Rep:22
09bighorn is on a distinguished road
Here's my theory on nitorgen in the tires. The air that we put into tires is about 80% nitorgen, so there is only a slight gain. Also there is air in the tires t start with, unless you put the tire into vacumn. So I feel as if it is only about 90% nitrogen total. The advantage is lost to me at that point. I have seen many times that even with nitrogen tires (they usually have green valve stem caps) the pressures are low or set to incorrect levels, usually overfilled by alot. I fall into the bad habit of never checking tire pressures ( I check them all day at work for other people) but i never check my preesures except for oil change time and I have never had a TPMS light come on, I have 2 cars with TPMS. System does work, it came on when I cut a sidewall.
tinted, remote start, slightly debadged, HID's, lockpick camera, truxedo deuce, Volant, linex ,more to come, just have to convince wife!
Old 02-20-2011, 11:12 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Originally Posted by 09bighorn View Post
Here's my theory on nitorgen in the tires. The air that we put into tires is about 80% nitorgen, so there is only a slight gain. Also there is air in the tires to start with, unless you put the tire into vacumn. So I feel as if it is only about 90% nitrogen total. The advantage is lost to me at that point.
Exactly, that means you are paying for an extra 10-15% nitrogen in your tires for what is maybe a really small increase in mpg. And now you have to deal with the pain of returning to those places that offer nitrogen when you need to add some. With todays CAFE standards and everyone trying to get that extra mile from every gallon you'd think every car manufacturer would offer nitrogen if it were that great.
Plus, I like being able to use my compressor to fill up the tires when needed and not depend on going to some shop and wait in line.
IMHO I'd use the free stuff to save yourself time and money.
Old 02-20-2011, 07:03 PM
moparornocar72's Avatar
Rep:630
to sum up what others have put, the amount of money spent for nitrogen does not justify it any better than air. correct me if that is wrong but thats how i feel aswell
14.268 @ 95 MPH Full Trim
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 11:31 PM
Has anybody ever heard of putting air shocks in the back, and it will lower it?? tractorpuller Suspension 5 02-22-2011 04:55 PM
Air Intake Opinion rumblebeezer Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 02-19-2011 12:56 AM
Replace air induction tube? alharm1 2011 Dodge Ram Forum 12 02-14-2011 01:34 PM
Nitrogen? RootBeer Dodge Ram Wheels And Tires 14 11-17-2010 12:07 AM
