Old 02-21-2011, 03:53 PM
USn2Boyz USn2Boyz is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: slt 4x4
Color: Bronze
USn2Boyz is on a distinguished road
Default Limited rear slipping?
I have an 01 3500 4x4, I have noticed mainly in turning at slow speeds I have a slipping feeling from the rear end.... Im not sure if it would be a limited slip thing or do I have a real problem? Any help will be appreciated...
Old 02-21-2011, 04:09 PM
I'm not sure what you mean by a "slipping feeling" .
Old 02-21-2011, 04:18 PM
Rep:2657
i noted that you have a 4X4, i hope that you are not using it when your on dry pavement, where you don't need the front differential engaged
Old 02-21-2011, 04:20 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Can you elaborate on the 'slipping feeling'?
brad
Interested in one of my mods?
Old 02-21-2011, 05:34 PM
sinned sinned is offline
Vehicle: 2011 Dodge Ram
Rep:5
sinned is an unknown quantity at this point
I suspect what you are describing is the LSD not releasing when turning and feels like something is suddenly releasing every 10 feet or so.
Try draining the fluid and refilling with the factory recommended oil with plenty of LSD additive. We were using an extra tube for customers with repeat concerns for this symptom.
If you find yourself in a fair fight, your tactics suck.
Old 02-21-2011, 06:28 PM
Trim Level: slt 4x4
Color: Bronze
No gtyankee, its not even in 4wd. I was talking aboit the rear, not the front diff.
Thanks sinned, I will drain it and try what you said. It truely feels like LSD slipping.
New Rear window with defrost 05DodgeRam2500 Dodge Ram General Discussion 16 02-11-2015 05:32 PM
My Build Sheet, Do I have Limited Slip Diff al2ride 4.7L PowerTech V8 Specific Topics 7 11-03-2011 10:35 PM
Rear End Questions.... jared1088 Suspension 2 04-18-2011 08:50 PM
Limited slip rear? topspin Dodge Ram General Discussion 12 11-21-2010 04:53 PM
Limited slip rear end. Silver Eagle Dodge Ram General Discussion 5 09-02-2010 11:02 PM
