Old 02-19-2011, 09:42 PM
foolioGrimz foolioGrimz is offline
Vehicle: 1999 dodge ram
Trim Level: 1500
Color: Green
Rep:56
foolioGrimz will become famous soon enough
Default ordered coil spacers
ordered 2" coil spacers and blocks from jc whitney. free shipping right now. can't wait to get them on. next will be the body lift and bigger tires.
mods-Ranch hand Brush guard, superchip tuner, 75 gal transfer tank, 4.10 gears with detroit locker, 305/70-16 BFG mudders, 2" lift, Chrome Edelbrock carb filter with throttle body mod, and a short glasspack.
Old 02-19-2011, 09:45 PM
ScatPak07's Avatar
Rep:970
Sounds good man. Post up some pics when you are done
Old 02-19-2011, 09:48 PM
SslagleZ28's Avatar
SslagleZ28 SslagleZ28 is offline
Vehicle: 2002 Dodge Ram
Rep:158
SslagleZ28 has a spectacular aura aboutSslagleZ28 has a spectacular aura about
great purchase, and you sure cant beat free shipping.
Backlash
Semper FI
Old 02-20-2011, 12:02 PM
Trim Level: 1500
Color: Green
Rep:56
yeah, a couple inches of lift for that cheap is great too. i wasnt thinking about shocks when i ordered it though. that can wait till next friday. when u remove the spring all u have to do is release the tension by jacking up the vehicle or is there still too much pressure in the spring after that?
Old 02-20-2011, 06:21 PM
Trim Level: 1500
Color: Green
Rep:56
or maybe ill just get a spring compressor
Old 02-28-2011, 04:21 AM
Trim Level: 1500
Color: Green
Rep:56
ok, almost got one side done but i'll leave it for tomorrow. it took me awhile to remember to hit the spindle with a hammer to remove the tie rod/ ball joint. Then i had a hard time getting everything compressed back together. The shock doesn't reach but im thinking about just picking up some aftermarket shox in town tomorrow. I hope there's some in stock because waiting a week to get parts is bull%$it. its 32o and im crashing out, got jury duty in the morning
Old 02-28-2011, 08:36 PM
Trim Level: 1500
Color: Green
Rep:56
ok, so i finished that side up when i got home and it was already getting dark when i started the other side. I didnt realize that part of the pin broke off on the tie rod and when i tried to break loose the nut the bolt spins with it now. screw it, im crashing out.
Old 03-01-2011, 05:44 PM
Trim Level: 1500
Color: Green
Rep:56
allright, got everything in and put back together. The front is noticably higher than the back now with the 2" coil spacers. It rides like a brick sh%T-house now. Im guessing that the shocks are hitting their limit everytime i hit a bump so I'll put an order for longer shocks. does anyone have any reccomendations? The zone and reilly's doesnt have any and of course can't order any. I chickened out on the rear end work and im taking it in to a chrysler dealership tonight so i'll either do the back when i get her home or see how much they want to put in the springs while its already taken apart.
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
Lifting via spacers vs via new struts Tommy Behind The Deuce Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 11-14-2010 10:14 PM
Leaf nd Coil spring spacers 20ramquad04 Dodge Ram Wheels And Tires 3 03-31-2010 10:24 PM
Leaf nd Coil spring spacers 20ramquad04 Dodge Ram Wheels And Tires 10 03-30-2010 10:21 PM
Coil spring spacers vs torsion keys ramjam02 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 01-25-2010 02:26 AM
