Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 02-20-2011, 12:34 AM
coralkp coralkp is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: 1500 2 wheel drive
Color: blue/silver
coralkp is on a distinguished road
Default Brake problem mystery need help???
Hello, bought my 2003 dodge ram 1500 2wd new in 2003. Had a problem where I think I had warped rotors. replaced them and the pads on both sides. fixed the wobble when braking. New problem with the brakes. They appear to be very soft when braking, almost to the floor. hissing sound when it happens. If the truck is not running seems like you can pump it a few times and seems to preasure back up. Would this be the master cylinder, or the power brake booster. plan on bleeding the brakes in the next week to see if this helps. Truck has just hit 81,000 miles.
Thanks for any insight
Tim Lynch
Old 02-20-2011, 11:11 AM
Have the brakes started to feel soft just after you did the brake job ? Let me know . Stop by the newbie section also and introduce yourself .
Old 02-20-2011, 11:15 AM
Rep:1885
If the hydraulics weren't opened, it's probably not air. It's most likely either something not reinstalled correctly or the master cylinder is bypassing internally.
Old 02-20-2011, 11:54 AM
Color: blue/silver
The system was not opened. had started before the brake job.
Old 02-20-2011, 12:56 PM
It could really be a number of things . I've even seen a brake caliper that isn't slidding evenly cause a low brake pedal . Best thing I can recommend to start is go ahead and bleed the brakes first . Who knows , that may fix it .
Old 10-19-2012, 06:53 PM
rebel1221 rebel1221 is offline
Vehicle: 2003 dodge ram 1500
Color: silver
rebel1221 is on a distinguished road
Default 2003 ram
hey did you figure out what was wrong. cause im havin the same problem
Old 12-17-2012, 04:12 AM
Tariqueislam's Avatar
Tariqueislam Tariqueislam is offline
Vehicle: 2000 Dodge Ram 1500 Magnum V8
Color: Brown
Tariqueislam is on a distinguished road
I recently changed the Brake pads and front rotors in my Dodge Ram 1500 Yr.2000 2WD. The chilton manual warned that a Scanner is needed for a 4WD model if bleeding is needed. So I happen to perform bleeding at the front wheel's brake cylinders, as one of the cylinders popped to much out and some air got in. Now my "ABS" indicator and the "Brake" (red) indicator lights are ON in the instrument cluster. Help!
Brake Problem cableguy493 4.7L PowerTech V8 Specific Topics 2 07-10-2010 03:51 PM
Anti-Lock Brake Wiring Problem dkeith Newbie Checkin! 7 04-25-2010 05:42 PM
Anti-Lock Brake Wiring Problem dkeith Electrical 1 04-23-2010 11:28 AM
03 dodge brake light problem j11mmy Electrical 4 11-02-2009 05:00 PM
brake problem 94beast Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 05-13-2009 01:46 PM
