EBC Pads or Power Stop Pads+Rotors? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Old 12-09-2012, 10:50 PM
MeanMango2010's Avatar
MeanMango2010 MeanMango2010 is offline
Vehicle: 2010 Ram 1500
Color: Mango Tango
Rep:59
MeanMango2010 will become famous soon enough
Default EBC Pads or Power Stop Pads+Rotors?
I am down to bare minimum on my pads right now and need a new set ASAP. I turned the rotors once before around 25K due to squeeling, so I'm thinking I will need rotors.
I am looking at either a set of Power Stop pads+rotors from AutoAnything for less than $200. The other option is EBC Green Stuff pads and EBC Sport Rotors for $300. Should I buy the PowerStop kit for $186.45 or EBC for 301.60?
I have only seen two opinions of PowerStop, one good and one bad. EBC on the other hand is a well known brand.
Also, if my rotors are turnable do you think I should just turn em and slap some pads on?
2006 Ram 2500 MegaCab Cummins - White Shadow
2010 Ram 1500 Mango Tango - Punkin XpressSOLD
Old 12-09-2012, 10:56 PM
Rep:3347
I am a personal fan of the EBC setup. It's been on 2 vehicles now and they've been very reliable and had very little brake dust. The most important thing to know, is to use the GreenStuff Supreme pads on the front since our vehicles are front-brake biased, you want the 'stronger' pads on the front or you'll have nothing but brake dust issues. Since you're making better than stock power levels with the RIPP, it might be prudent to upgrade your braking ability with the EBCs.
If your rotors are turnable, then stick with the Power Stops, but if you need to replace everything, I'd spend the extra and get the EBC.
Old 12-09-2012, 10:59 PM
Color: Mango Tango
Rep:59
Also, with EBC pads would anyone recommend another brand rotor?AutoAnything has DBA and Brembo listed for my truck. Just looking to see what everyone's opinions are.
Old 12-09-2012, 11:10 PM
Color: Mango Tango
Rep:59
Did you mean that the other way around? Cause the PowerStop only comes in a kit with rotors and pads. I have to order the EBC stuff seperately.
Old 12-09-2012, 11:22 PM
Rep:3347
I meant it exactly as I said it. I can order PowerStop pads through Napa, didn't look at AA, so I didn't realize it only came as a kit. I personally avoid cross-drilled rotors like the plague, the EBC's are only dimpled, so they don't generate the same thermal expansion stress as a cross-drilled does.
Looking at AA, the less than $200 is only for one set of pads/rotors. Are you planning on only swapping the fronts?
If you wanted a different rotor, then I'd look at the Power Slot Cryo rotors. The more rotor face you have the more stopping power you have, so having just a vented rotor is better than having just a cross-drilled
Old 12-09-2012, 11:38 PM
Color: Mango Tango
Rep:59
So do you think Power Slot Cryos are worth the extra $80?
For now I'm just doing the fronts, the rears have close to half life left still.
Old 12-11-2012, 08:58 PM
Color: Mango Tango
Rep:59
Got the front wheels off today and measured the rotors. They measured 1.084 and machine spec is 1.035. They will be just slightly above spec when I'm done. But I think I will just machine them and put the EBC Green Supremes on.
