leveling kit add on - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-08-2011, 11:02 PM
dirtrider29's Avatar
dirtrider29 dirtrider29 is offline
Vehicle: 2007 Dodge ram
Color: mineral grey
Rep:15
dirtrider29 is on a distinguished road
Default leveling kit add on
Hey whats up guys i am about to order a complete set of bilstein 5100 for my 2007 ram 1500 4x4. In the near future i also want to add another inch or two of lift to the front and the same in the back. Will i be able to do this with the bilstein 5100s and what size tire and rim would look good on that aswell and if you have pictures that would be a plus thanks
Old 02-08-2011, 11:27 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
You will love the bilsteins, and I think those shocks are good for up to a 4" lift...
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 02-09-2011, 12:16 AM
Color: mineral grey
Rep:15
alrights thanks man. U know whats the biggest size tire i can go without rubbing
Old 02-09-2011, 12:19 AM
BLKSVT's Avatar
Rep:222
Im running a 305/55/20 (33") on stock rims and had to use a 1/4 spacer to clear.
Old 02-09-2011, 12:24 AM
Rep:1625
How were you planning on adding another inch of two to the front after you install the Bilsteins? (assuming you install the Bilstein's at the 2" setting)
Old 02-09-2011, 12:31 AM
BLKSVT's Avatar
Rep:222
Probably a body lift.
Old 02-09-2011, 12:51 AM
Color: mineral grey
Rep:15
Not sure how to add the other inch or two what do you think the best way to do it would be. Any inch or two suspension spacer or something don't really know to much about this stuff lol. And do you have any pictures of your truck with 305/55/20s?
Old 02-09-2011, 12:59 AM
Rep:1625
Well you can't add a spacer on top of the Bilsteins. You could get the Bilsteins and install them now, and if you want to lift it higher later on, you could get a 4" suspension lift and reuse the Bilsteins. That's one way to do it. Or you could do like BLKSVT said, and get a body lift.
Old 02-09-2011, 01:05 AM
Color: mineral grey
Rep:15
What's a good brand to go with for the 4 inch lift and how much does it usually go for? And to keep the truck level with a 4 inch lift in the front what should go in the back a 1 inch block?
Old 02-09-2011, 01:11 AM
Rep:1625
BDS makes nice 4" lift for your truck. Here's the link to their kit (Click 4" under 'Step 1'): http://bds-suspension.com/product?ma...3&yr=2006-2008 You might want to talk to BigHorn 4 Life, he gets people good prices on BDS lifts. A 2" rear block would probably sit level.
Leveling kit on a 2WD? thumper36 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 11-27-2010 06:22 PM
2WD Leveling Question bigedschukar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 20 11-18-2010 09:20 PM
Leveling kit and tires UnLiMiTeD 2010 Dodge Ram Forum 41 11-04-2010 10:17 AM
Quoted $1373.50 for alignment after Installing Leveling Kit doozy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 11-01-2010 10:20 PM
Need help with newly installed leveling kit! PLEASE! Who Dat Ram 2010 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 06-04-2010 09:36 PM
