Old 02-20-2011, 09:50 AM
BigDave52952 BigDave52952 is offline
Vehicle: 2007 Ram 1500 Quad Cab
Color: Inferno Red
Rep:26
BigDave52952 is on a distinguished road
Default Air suspension
Hi fellow Rammers;
I have an '07 Ram 1500 quad cab short bed. I am looking to beef up the rear suspension a bit. I need something adjustable 'cause I don't want to stiffen the ride when I'm not hauling. I don't pull anything over 5,000 lbs. and never exceed about a 600 lb tongue weight. I do carry some heavy tools and materials at times [maybe about 1200 lbs]. I'm looking at the fallowing two kits and was wondering if anyone had any experience with either one. Like I said I want to retain the good ride I have when the ram's not loaded.
http://www.truckspring.com/suspensio...rol-59551.aspx
http://www.truckspring.com/products/...ear__2286.aspx
Thank you in advance,
Dave
Old 02-20-2011, 10:01 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I would go with the Firestone Ride right, Firestone is the top dog for air bags.
Old 02-20-2011, 06:28 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
If all you do is moderate towing and want a simple answer and install look into the timbren ses kit. Your ride is totally unaffected until your rear sinks about an inch then the rubber stoppers come into play. Install takes 15 minutes
Old 02-20-2011, 06:40 PM
TD52's Avatar
TD52 TD52 is offline
Vehicle: 1996
Trim Level: SLT Laramie
Color: White/ Silver and White / Silver custom
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
TD52 is on a distinguished road
there are systems out using Firestone bags .. but it removes the rear springs .. and replaces it with a whole new air system .. that can have 12,000lb's of center weight .. like from a goose-neck and also a 5th wheel .. but when you are unloaded .. it runs as empty and rides like a caddy ... cost is a bit more than you may want to spend ... but I rode in one and thought I was in a car down the road and on dirt roads .. if I could come up with the money .. I would have that system installed
But air is the way to go any way you want to look at it .. now you say you do not haul heavy there is a air bag system that runs at the back of the springs .. better rid .. but you will only be able to handle the OEM weight .. no extra
and it rides great .. a lot better than the helper ones
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 157 09-21-2014 09:47 PM
Snowplowing with my 1500 johnf15 2010 Dodge Ram Forum 7 11-29-2012 04:32 PM
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 11:31 PM
Body lift vs Suspension lift ccga3359 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 2 12-19-2010 09:22 PM
Bilstein 5100 / Roadmaster Active Suspension ram1hemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-09-2010 06:57 AM
