Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 02-20-2011, 11:41 AM
Larrin's Avatar
Larrin Larrin is offline
Vehicle: 1995 Dodge Ram
Color: Fire Engine Red
Larrin is on a distinguished road
Default 318 swap
Hello everyone!
Much like the person below me posted, am interested in swapping a 318 for a 360. Am just worried about the differences.
I have a 1995 Dodge Ram 1500 with a 5.2L Magnum, automatic transmission. The engine actually froze and busted the block due to someone adding water instead of antifreeze…and I have had a difficult time finding a replacement for it. I have however come across a 5.9L out of a 1994 Dodge van but am worried about the differences in year as well as the larger engine size. Would I be able to replace the 1995 318 with the 1994 360? If so what has to be swapped out to make it work? Or if not, what’s different about them?
Thanks in advance for any help
Jasonitodd@hotmail.com
Old 02-20-2011, 11:58 AM
With the motor coming out of a van , you will need to verify that the oil pan and bolt on accessories are the same . The basic motor is of the same design so it will bolt right in . The 5.9 is a externally balanced engine so you will need to change out the torque convertor or you will have a vibration that you won't beable to get rid of . The computer from the 5.2 will work on the 5.9 , but the basic specs will need to be reflashed for the 5.9 engine .
360 swap help! sandman1 Electrical 13 07-08-2010 12:49 AM
To swap or not to swap...that is the question Travis Dodge Ram General Discussion 10 02-18-2010 03:47 AM
Dodge 1500 Engine swap 1997 318 into a 1998 gourash 5.2L V8 Specific Topics 3 11-19-2009 05:10 PM
Gear swap J1M Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 0 08-23-2009 01:40 AM
Engine swap? hotrodder Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 2 05-31-2009 06:40 PM
