fuel mileage??? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-20-2011, 12:20 PM
malebiker1 malebiker1 is offline
Vehicle: 2001 ram 1500 5.9 auto
malebiker1 is on a distinguished road
Default fuel mileage???
I have recently purchased a 2001 ram with a 5.9 auto ext cab shortbed 2wd.
My issue is that we used to have a 97 ram with a 5.2 auto.Our fuel mileage was17-18 mpg
the truck gets no better than 13 mpg hwy Is this avg? or is it too low?.
Besides the obvious (tire pressure,throttle control,tune up) any ideas?
Old 02-20-2011, 01:22 PM
I'm not sure if in Texas you run oxygenated fuel in the winter . If you do , that really effects mileage . You can also check for any vacuum leaks . Back last winter , with the 3 blizzards the Baltimore area had , I was averaging 7.6 mpg . Sucks . I did a water pump on my truck this past summer and did find quite a few vacuum leaks that I went ahead and fixed . Seems to have helped . Heres a pic of one of the lines that I found several leaks on . Trace it all the way from the throttle body , to the firewall , then to the front of the r/f fender .
Old 02-20-2011, 10:35 PM
I can check again .
Thanks
Old 02-24-2011, 06:04 PM
StarDeficient's Avatar
StarDeficient StarDeficient is offline
Vehicle: 2001 Dodge Ram 5.9L Magnum
StarDeficient is on a distinguished road
Hi Malebiker! I've got almost the same truck (2001 5.9L extended cab short bed 4x4) and I started out with that same gas mileage. I've had my big boy for about 5 months now and I'm a major highway driver (56miles a day, twice a day, 5 days a week), and that 13mpg is as good as I've gotten. I've noticed with mine that if I keep up on the oil changes and keep my fluids in top shape, my mileage stays around the 12-13, but lately I've been slacking and it's dropped down to 10-11. Maybe it's just how I'm driving, but it seems more consistent with the times I've checked and watched my fluid levels.
If you find a way to get higher gas mileage, LET ME KNOW!, cause that would be awesome. But it's highly likely that that 13mpg is gonna be as good as it gets. =\
Old 02-26-2011, 08:53 PM
LittleMoe's Avatar
LittleMoe LittleMoe is offline
LittleMoe is on a distinguished road
I have a 94 5.9 4x4 short box, and 13 is as good as i get !!!! i would think a 2 wheel drive should get a bit better because the 4x4 gear weighs a bit !!!! Make sure you have the stock size tires, that could make a huge difference. Also, after i gutted my cat out, i got better milage.If your truck has over 100k and has the stock converter, consider gutting or changing it. hope this helps a little .....
Old 03-02-2011, 01:52 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
sorry to say but its a 360 lol every 360 mileage ive ever heard anyone was getting was the best of 13 mpg
my brothers gets 13.
i have the 318 and im getting average of 16.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-02-2011, 02:08 PM
hauser775's Avatar
hauser775 hauser775 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:67
hauser775 will become famous soon enough
Drive slower on the highway.....if you do 75 your mileage is gonna suffer big time. I get about 13.5-15 on the highway doing about 65-70 average.
Old 03-04-2011, 01:28 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
well, my lil 03 only gets 12-13 if i drive normal, but if i baby the HE&& out of it, i can muster 14.9. 13 miles 1 way commute to work at 65-67 mph and i've got 3.55s pegleggin it. TOTALLY stock.
miss my 03 4.7 qc 2wd. it got 14 in normal driving at 65-70. take it down to 55 and i could eek out 18mpg w/ 3.92s Sure-grip
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 03-05-2011, 01:26 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I get 10. I recently got a Superchips and I am testing to see what the best mileage is.
Old 03-05-2011, 01:42 AM
DeputyNelson's Avatar
DeputyNelson DeputyNelson is offline
Vehicle: 1998 Dodge Ram 1500
Color: Red aka AWESOME!
Rep:86
DeputyNelson will become famous soon enough
I pulled 11.3 on my last fill up. Let's just say I was pretty darn excited!
"Blessed are the peacemakers, for they shall be called the children of God" Matthew 5:9
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Fuel mileage Redlongbed Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 09-11-2011 10:40 PM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 08:54 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 11:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
