Old 02-20-2011, 10:59 PM
984wdram 984wdram is offline
Vehicle: 1998 dodge ram
Color: deep amythest and silver mist
984wdram is on a distinguished road
Default major electrical problem
i put LED bulbs for my front turn signals. i snipped the wires today to install an 8 ohm resistor on them, one at a time, and tried to use it. the only one wired at this time was the right front one. it started ticking normal, and i thought i was in the clear. i looked at my dash, and every time the arrow turns on, the odometer display cuts off. also, every single light minus the one front bulb and headlights flashes, even the license plate lights. i unhooked the resistor and rewired the socket back to the truck by itself and it does the same thing still. also, when i turn the headlights on, the right turn signal arrow comes on and stays on. wtf is goin on with this thing? im stumped on whats goin on. also, that park light wont come on.
Old 02-21-2011, 08:53 AM
Rep:1845
Sounds like it could be a bad ground somewhere.
Old 02-22-2011, 02:03 AM
it was fine b4 i tried the resistor. just hyper flashed. i have no idea on what the problem could be and im usually pretty good on findin stuff out. im gonna try the ground deal, but i have no other clue on what else it could be.
Old 02-22-2011, 04:20 AM
well i went to try to reground the bulb a couple minutes ago. got everything out and looked between the radiator and ac condensor and found one of my old regular bulbs. just for s&g's, i plugged it in b4 i rewired the ground. it works fine. what the he double hockey sticks? the only thing i can guess is the resistor i used was too much and messed up something inside the bulb. the research i did said to use a 6 ohm resistor and i used an 8 ohm. would that have done it?
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 07:45 PM
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 01:10 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 05:54 PM
Ingnition problem 808state V10 Specific Topics 4 10-31-2009 11:36 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 05:37 PM
