Old 02-21-2011, 02:36 AM
fsca72's Avatar
fsca72 fsca72 is offline
Vehicle: 1994 Dodge Ram 2500
fsca72 is on a distinguished road
Default idle issues
after looking through all the threads i could not find one similar to mine. i have a 94 2500 2wd 318 204000 miles (i know its an odd setup but it has plenty of pulling power). when i start it up it immediately has a kinda rough loud idle and runs lean then after 5 min or so its like somebody snaps their finger and the idle smooths out and runs a little rich. if i try to drive it cold it hesitates real bad and has no power at low rpm and has a hissing whistling sound i can hear in the cab. once it warms up till the thermostat opens it has and intermittent miss about every 5 seconds. i got a new plugs and wires, o2 sensor, coolant temp sensor, computer, and i beat the crap out off the egr to free it up. that took care of all the codes that it was throwing but i still got the problem. it did burn quiet a bit of coolant last winter but it has not this year. im going replace all the gaskets on the top end here soon. im going to check if the plenum gasket is leaking today and clean up some of the sensors and get some resistance readings. i just wanted to get some feed back to see if anyone had the same issues or if any of ya got some idea's.
Old 02-21-2011, 02:38 AM
fsca72's Avatar
the miss is only at idle, at 1000 rpm's it goes away
Old 02-23-2011, 12:50 AM
fsca72's Avatar
it was just the idle air control valve that was all gunked up. i gave the throttle body a nice cleaning also. seams to have a boatload more bottom end power now.
Old 03-02-2011, 01:25 PM
speedymph1000's Avatar
speedymph1000 speedymph1000 is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Gloss Black/Silver
speedymph1000 is on a distinguished road
Good deal man. Hope it treats You good for another 100,000 miles or so... LOL!
When in doubt use a hammer... The bigger the doubt the bigger the hammer!
Idle and misfire issues 413stroker Newbie Checkin! 9 02-17-2011 09:44 PM
95 ram idle issues 64fury 5.9L V8 Specific Topics 1 11-15-2010 06:50 PM
idle issues blacdog06 5.7L V8 Specific Topics 3 06-19-2010 06:06 PM
Idle Issues on '96 5.2L vwalburn 5.2L V8 Specific Topics 1 04-18-2010 08:18 AM
Idle issues SgtMajBilly 5.9L V8 Specific Topics 7 01-22-2010 11:21 AM
