Old 02-21-2011, 11:59 AM
MUDLIFE MUDLIFE is offline
Vehicle: 1998 Dodge Ram 1500
Color: BLACK
MUDLIFE is on a distinguished road
Default HELP Truck is misfiring
i have a 98 ram 1500 4x4 it was misfiring so i did a full tune up plugs, wires, rotor, cap, etc. But this still didnt fix the problem, what else could it be and whats it gonna cost me???
Old 02-21-2011, 01:52 PM
Rep:1877
Coule be a lean miss, broken valve spring, bad O2 sensor, bad CKP sensor, PCM...Have you checked for any codes?
Old 02-21-2011, 04:21 PM
Color: BLACK
Thanks for the response, yea i just checked for codes it says fautly upstream o2 sensor and cylinder #7 misfire... Could this be due to a vac leak?
Old 02-22-2011, 10:59 AM
keegles's Avatar
keegles keegles is offline
Vehicle: 1998 dodge 1500
Color: driftwood
Rep:19
keegles is on a distinguished road
mine was misfiring too. i just had to replace a bent push rod and valve spring on mine. real easy to do. shit, i have valve stem seals, a push rod, and a spring for ya if you need them. for free
Old 02-22-2011, 11:52 AM
Rep:1877
Yes, a bad O2 sensor can make one run like crap. You should also check for a plenum pan gasket leak.
Old 03-02-2011, 02:19 PM
speedymph1000's Avatar
speedymph1000 speedymph1000 is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Gloss Black/Silver
speedymph1000 is on a distinguished road
Mine was doin the same but I dont think quite as bad as Yours is sounding and My problem was a broke plenum gasket. I think the gasket kit was $22 from o'reily's. Give it a check. take off the air cleaner and open the baffles look through them into the plenum and see if there is oil there. If so, You'll need a new plenum gasket.
When in doubt use a hammer... The bigger the doubt the bigger the hammer!
Old 03-03-2011, 09:31 PM
NuclearRam's Avatar
NuclearRam NuclearRam is offline
Vehicle: 2001 Ram 1500
Trim Level: Laramie SLT Quad Cab
Rep:20
NuclearRam is on a distinguished road
My 01 is having a similar problem. There's a noticeable lack of power at higher speeds as well as some rumbling throughout the whole truck coming from the engine compartment.
What I THINK the problem is comes from the last time I changed the spark plugs. Cylinder 7 is the one that's misfiring, and when I changed the SPs last time, I inadvertently damaged the wire leading to the cylinder. I managed to fix it, but I want to think that it's having issues again.
Old 03-09-2011, 02:33 AM
Yeah You gotta becarful for the wires those thing are a little more fragile than they look. lol
Old 03-15-2011, 11:11 AM
redneckram2001 redneckram2001 is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Trim Level: SLT Laramie
Color: Forest green and silver 2 tone
redneckram2001 is on a distinguished road
check your plenum gasket. if its blown i highly recommend a hughes plenum repair kit. it comes with a 1/4 thick aluminum plate all new gaskets and shorter lenght plenum bolts. all you need is new intake bolts which you can get from the dealer, which will run you about 20 bucks, or you can get them from hughes added to the kit.
2001 Dodge Ram 1500 QC 4x4 auto, 360 swapped, and built, diesel coils, 2"aal, 8' HD Fisher plow
Old 03-15-2011, 12:38 PM
Rep:1877
Someone will have to explain the big to-do about these Hughes kits to me. Stock pans work just fine with the updated gaskets and spending money on these kits seems like a waste to me.
Truck in shop for tranny problem Fuzznutts 5.7L (345 cu in) HEMI V8 Specific Topics 17 01-24-2014 11:19 AM
My truck got hit yesterday. GeauxHunting Dodge Ram General Discussion 41 11-19-2010 02:15 PM
Rumor: sounds like a new SRT truck is coming partypooper Dodge Ram General Discussion 7 11-12-2010 03:08 PM
Dirt Builds Up in the Bed of My Truck Rocky Harbour 2010 Dodge Ram Forum 4 05-27-2010 01:23 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
