Tire Size??? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-21-2011, 12:05 PM
USn2Boyz USn2Boyz is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: slt 4x4
Color: Bronze
USn2Boyz is on a distinguished road
Default Tire Size???
Ok Im sure it has been gone over many times but.... I have an 01 3500 4x4 with a leveling kit.. Im running 265/75/16 now. What is the max tire I can run on these stock rims? I definatley what a larger tire but dont want to buy wheels... Sorry for asking a question that has been beat to death but I dont get on here much so I thought I would ask again...
Thanks guys
Old 02-21-2011, 09:20 PM
Trim Level: slt 4x4
Color: Bronze
Does no one know what the max tire size I can go with!?!?!?
Old 02-23-2011, 10:43 PM
ScatPak07's Avatar
Rep:970
The only thing that would stop you from going with a bigger tire on a rim would be the width. If the width of the tire is too big for the width of the rim then they will not work properly. Height wise you can put whatever height on a rim. So if you know the width of your rims then you should not go over 3" more on the width. Some tires can go 4" more then the rim width.
If you have a 3500 with a leveling kit then I would think you can fit a 33" for sure maybe even a 35". I am not too sure about the 2nd gen trucks so dont take my word for it
Old 02-26-2011, 09:13 PM
06dodge1500's Avatar
06dodge1500 06dodge1500 is offline
Vehicle: 2006 Dodge Ram
Color: Tan
Rep:13
06dodge1500 is on a distinguished road
I have a 2006 Ram 1500 with a 2.5 leveling kit and 35's fit on it with a 20 inch rim. Had to trim the fenders up a little bit because the tires would rub if the wheel was cranked but not much at all and cant even notice. Not sure on the 2nd generation though but with a 3500 you should be able to fit 35's with a leveling kit installed. Head down to your local tire store the will be able to tell you what should fit and what wouldnt.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Tire size? CHADDER03 Dodge Ram Wheels And Tires 7 01-24-2012 01:46 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Tire size feature not accurate FDBDW Diablo Predator Questions & Info! 6 01-26-2011 09:05 AM
Tire Size 01RAMguy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 04-21-2010 11:37 PM
