Old 02-21-2011, 12:28 PM
ramfan1500 ramfan1500 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: trx
Rep:63
ramfan1500 will become famous soon enough
Default upgrade side mirrors/ warning
I have a 2010 trx cc 1500 that came with the side mirrors without the turn signal lights in them. I purchased a set that came off of a new 2011 with the lights in them and installed them on my truck. The mirrors worked as far as movement and defrost but no lights. I took it to my dealer to have them flash the evic hoping it would let them turn on the light/blinker function in the mirrors.They spent nearly 3 hrs working on them to get them to work and they never could get them to work. They told me that the system was asking for a code and that since my truck did not come with them from the factory that it is not possible to turn them on. Anyone know what that code might be? I still feel like there has to be a way to turn them on, any help would be great.
Old 02-21-2011, 12:44 PM
billwill81's Avatar
billwill81 billwill81 is offline
Color: Pewter
billwill81 is on a distinguished road
Default Mirrors
This is an upgrade that I have wanted also. From what I have read, No one has succeeded. Let us know if you have any success.
Old 02-21-2011, 06:45 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
i have the towing mirrors with turn signals and puddle lights the codes for them on my build sheet are:LEBP ext.mirrors w/supplemental signals & LECP exterior mirrors courtesy lamps maybe those will help?
Old 02-22-2011, 09:16 AM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
I have no idea what codes they could be looking for but my build sheet shows: GNZP Auto Dim Exterior Driver Mirror
GUKP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 02-22-2011, 09:37 PM
Trim Level: trx
Rep:63
Thanks for the codes, I will take these to my dealer and see what they say.
Old 02-23-2011, 10:08 AM
mrsprinkler mrsprinkler is offline
Vehicle: 2010 Dodge Ram 2500 Crew Cab
Color: Grey
mrsprinkler is on a distinguished road
I think you need one more wire in the harness to the mirrors if you add the puddle/turn lights to one with out them. Does the harness off the new mirrors have the same number of pins as the connector from the truck? Make sure to actually count the pins and not just look at the holes.
Old 02-23-2011, 09:51 PM
ssfd110 ssfd110 is offline
Vehicle: 2010 1500 QC 4x4
Color: Mineral Gray
Rep:28
ssfd110 is on a distinguished road
I have a 2010 1500 Sport. I just swapped out my stock mirrors for towing mirrors. I'm not sure of my codes. My stocks were heated with turn signals and puddle lamps and also had auto dimming feature. The Tow mirrors have Heat, turn signals and puddle lamps. I'm not sure if they are supposed to dim or not but they don't and I was wondering about a flash as well. I can tell you that both mirrors had the same two electrical connectors.
Mike
4" Super Lift, Pro Comp 7098 Flat Black, 35 x 12.5 Nitto Trail Grapplers
Old 02-23-2011, 10:06 PM
Rep:2657
my '09 Quad Cab SLT build sheet reads
LEPB ext. mirrors w/ supplemental signals
LECP external mirrors courtesy lamps
GVBC all vehicles w/ power mirrors
NHJP exterior mirrors w/ heating element
ADAP light group
I was wondering about the inside auto dimming mirror, how it works, etc
i know that pushing the button on the mirror makes the little green light come on & it seems to dim the lights from the vehicles in back of me, i watched closely as i did the button pushes, i did it several times, then i realized what is actually happening
Just like the mirrors in older vehicles that had the little lever on the bottom of them, at night you moved that lever & the mirror swivels down slightly, & you were not blinded by vehicles lights that were behind you at night
the little button on our Rams does the same thing
http://www.autoanything.com/GenericP...ProductID=2981
So next time that i have some night driving to do, i am going to try pivoting my outside mirrors down to see if it removes some of the glare, i believe it will
Old 02-23-2011, 11:17 PM
Trim Level: trx
Rep:63
I appreciate the replies on this issue. I talked with my dealer and told them about some of the codes I have been given on here that came off of other trucks build codes that came with the lighted mirrors. They told me that will not help because those trucks came factory with the upgrade mirrors and the evic recognises those codes. I think my dealer is kinda blowing me off after spending 3 hours the first time on this issue. My problem with that is that if a customer was thinking of buying a new truck already on the lot that had standard mirrors without lights, and said I will buy this truck if you add towing mirrors with puddle lights, you can bet they would make that change. IF you can make it work on optional tow mirrors, why cant you with these upgrade mirrors? Makes no sense to me, there has to be a way. One thing that did change when I added these mirrors over my stock ones were that they dim like my inside mirror does at night, they did this before I took the truck to the dealer to get the lights working.
Old 02-23-2011, 11:39 PM
Rep:2657
so they are saying that the mirror OPTIONs have to some how be added to YOUR Rams VIN #s build specs
i think that that has to be done by the manufacturer
the dealer won't be able to do it
maybe one of the members that work for that manufacturer parts dept. can tell you how it could be done
i know that one of them tried to get a brake controller added to their build specs & ran into a snag, but, he had not given up yet
Side view mirrors bamamat Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 3 06-08-2011 01:18 PM
Side mirrors jojo13 2010 Dodge Ram Forum 2 01-11-2011 03:34 PM
ST upgrade to turn signal mirrors? Chinchilla 2010 Dodge Ram Forum 7 12-28-2010 12:45 AM
Side Mirrors drag737 Electrical 8 09-10-2010 10:58 PM
Activating Side Heated Mirrors & Radio Traffic Warning Sign removal? RammD Dodge Ram General Discussion 2 07-31-2010 01:28 PM
