Old 04-16-2012, 10:16 AM
sumncguy sumncguy is offline
Vehicle: 2012 Ram Crew Cab Express 4x2
Rep:16
sumncguy is on a distinguished road
http://www.**************/forums/sho...d.php?t=337889
Edited .. well I guess you cant link to other Dodge forums.
There are pins missing on the door modules it looks like. I will know for sure in a few minutes when I get into mine. I will post a pic of the pins ...
Old 04-17-2012, 06:10 PM
P-Rez's Avatar
P-Rez P-Rez is offline
Rep:28
P-Rez is on a distinguished road
Bump bump bump it ip!
P-Rez
Old 04-17-2012, 10:41 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
JUST FYI. If you add an option that needs to be added to the vin or the build sheet. The dealer can and will or should add it threw the dealer connect system. I know this because. I did some radio work. And had the dealer add the rear ves function to my radio and he had to add the sales code to my vin number to get it to work properly. So if they are telling you they need a code and the evic is looking for a code they need to add a sales code to your vin number in ram computer system or dealer connect. Than they need to flash the system. And all should work? If every thing is wired right and the sales code match what you are doing. You sould be good. Good luck lemme know what happens
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 04-20-2012, 12:54 PM
TCwald's Avatar
TCwald TCwald is offline
Vehicle: 2010 Dodge Ram 4X2
Trim Level: TRX
Color: Inferno Red
Rep:27
TCwald is on a distinguished road
When I bought my 2010 TRX I specifically asked for the light package, basically means the mirrors have turn signals, puddle lights etc. When I received it it didn't have them on. The dealer installed the new mirrors and only the turn signals worked.
Apparently they had to call the engineering department at the factory where it was built and obtained a code.
Tom
Old 04-21-2012, 09:10 AM
Holleywud's Avatar
Holleywud Holleywud is offline
Color: Austin Tan Pearl
Holleywud is on a distinguished road
GYSNST2 is correct to the best of my knowledge. I have added factory remote start systems to Chrysler products and they have to added on to the VIN. The process isn't the easiest, but it can be done.
Old 04-22-2012, 05:28 AM
dawg11's Avatar
dawg11 dawg11 is offline
Vehicle: 2010 Hemi Ram 1500 Crewcab 4x4
Color: Brilliant Black with Pearl Coat
dawg11 is on a distinguished road
I talked to the local dealer about adding uconnect , remote start and security systems to my 2010 SLT . He said there would be no problems , once the componets were added it was a simple system update with the computer .
Pro Comp leveling kit , Locking billet fuel door , Cabin air filter , Spay in Bedliner , 180* stat , Catch can , Tailgate assist , U-Connect Phone , K&N 63 Series C.A.I. . Flowmaster Super 44 . Dual Exhaust . Eaton TruTrac LSD
Old 04-23-2012, 06:38 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:184
I have 09 ram sport and would like the tow mirrors just like everyone. I found some and in the description it tells you they will not fit 1500. Is this true?
Thanks
Bryce
Old 05-07-2012, 11:14 PM
jkotys jkotys is offline
Vehicle: 2011 Dodge Ram 1500 QC 5.7
jkotys is on a distinguished road
I bought my truck last June 2011 and the window sticker listed the mirrors with puddle lamps. Mine only had the standard mirros so I brought this up to the dealer. In November they finally received the mirrors and installed them but still could not get the puddle lamps to work. Its been there 3 times, recently last week to no avail. They tried adding it through dealer connect but just wont work. They said dodge is not helping. I opened a case complaint with Dodge on Friday and waiting for a call back from them this week.
Side view mirrors bamamat Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 3 06-08-2011 02:18 PM
Side mirrors jojo13 2010 Dodge Ram Forum 2 01-11-2011 04:34 PM
ST upgrade to turn signal mirrors? Chinchilla 2010 Dodge Ram Forum 7 12-28-2010 01:45 AM
Side Mirrors drag737 Electrical 8 09-10-2010 11:58 PM
Activating Side Heated Mirrors & Radio Traffic Warning Sign removal? RammD Dodge Ram General Discussion 2 07-31-2010 02:28 PM
