Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 02-21-2011, 01:24 PM
Mcbride's Avatar
Mcbride Mcbride is offline
Vehicle: 2011 ram 1500 Crewcab 4x4
Trim Level: Sport/SLT
Rep:13
Mcbride is on a distinguished road
Default Help me choose a diff gear to buy
Hello everyone, I am considering the purchase of a new dodge diesel.
It will be either a 2500 or 3500 single rear wheel truck, and with a diesel, and manual tranny, as i HATE automatics.
It will be used for everything, from errand runner with no load, to carrying a good pile of weight in the box sometimes, to towing any one of my several trailers that vary from a low of 4500 pounds, up 11,000 pounds.
It will spend a fair bit of time on the highway, at speeds around 90 to 110 kms/hr. ( thats about 55 MPH to 70 MPH) my question is what diff gearing is best for this use.
I want to get decent mileage when cruising the HWY unloaded, but not so tall it struggles too much when towing a load up a mountain pass.
Thanks in advance.
Its not a mistake that mans best friend cannot talk.
Old 02-21-2011, 02:13 PM
Rep:1885
I'm thinking 4.10.
Old 02-21-2011, 06:28 PM
sledpuller2006 sledpuller2006 is offline
Vehicle: 2006 cummins
Color: silver
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
sledpuller2006 is on a distinguished road
well sorry i dissagree. i have an 02 with 4.10 and our pulling truck has 4.10... ahggg. the sweet spot for milageis 1800-2100 rpm cummins really doesnt make power after that , even my pullin truck the dyno chart starts to fall rapidly after that... but wheel speed is the key aso there.. they make the torque i as 3.73 or even heck 3.42 thats trully what im thinking in throwing in the 02 i drive dayly. DO NOT GO WITH 4.10 u will lose 3 to 4 mpg. Sorry if i pissed anyone off but its FACT!!!!!!!
Old 02-21-2011, 06:31 PM
Color: silver
With the signatures u guys have that have asked the ??? and have answered remember the cummins is throwing down 2 times the torgue u r...And doesnt turn the RPM those motors do either.. JUST MY 2 CENTS
Old 02-22-2011, 07:20 AM
79ta 79ta is offline
79ta is on a distinguished road
I would opt for the 3:73's , I have those in my 09 and they are an all around good gear when pulling your trailers or on the highway.
Old 02-22-2011, 12:06 PM
Mcbride's Avatar
Rep:13
Thanks for all the replies.
I know the 3.42 gears are stock, just wondered if i should stick with them or go for a higher ratio.
I do not want to ruin the fuel mileage, but also do not want it to struggle too much when towing, despite its being a light trailer for a diesel really.
Old 02-22-2011, 12:22 PM
Rep:1885
I don't know where you're getting your info, Mcbride but the 2011 model 2500/3500 isn't offered with a 3.42 regardless of which engine you choose. Available ratios (depending on which rear axle and truck) are 3.73, 4.10, 4.44, 4.56, or 4.88. If you're pulling 11k up a mountain pass, the 3.73 isn't going to be the best choice. If you primarily tow in flat land, it would be ok and you would see better economy.
Old 02-22-2011, 06:51 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
3.73s and a dpf delete and you'll see plenty of power and good fuel mileage
Old 02-22-2011, 08:57 PM
Color: silver
AMEN....I also thought we where talking TRUCK not a C/C
Old 02-23-2011, 09:11 AM
I agree 100%. I've done it and get 20+ mpg with unbelievable power. Don't forget, you will need a tuner with the dpf delete.
Rear Diff Recall #10V656000 LineCutter 2011 Dodge Ram Forum 40 04-02-2011 12:17 PM
45RFE sensors and rear gear change partymn Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 11-28-2010 07:45 AM
1st and 2nd gear WHINE JakeRam02 4.7L PowerTech V8 Specific Topics 2 09-21-2010 11:02 AM
Backlash setting ccdelay 5.2L V8 Specific Topics 1 09-06-2010 12:02 PM
Gear Ratio and Diff type nitrousjunky Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 12-22-2009 06:03 PM
