Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 02-23-2011, 05:45 PM
Mcbride's Avatar
Mcbride Mcbride is offline
Vehicle: 2011 ram 1500 Crewcab 4x4
Trim Level: Sport/SLT
Rep:13
Mcbride is on a distinguished road
Originally Posted by RamTech View Post
I don't know where you're getting your info, Mcbride but the 2011 model 2500/3500 isn't offered with a 3.42 regardless of which engine you choose. Available ratios (depending on which rear axle and truck) are 3.73, 4.10, 4.44, 4.56, or 4.88. If you're pulling 11k up a mountain pass, the 3.73 isn't going to be the best choice. If you primarily tow in flat land, it would be ok and you would see better economy.
http://www.dodge.ca/en/vehicle_home....=3500_3500_SLT
Right on the dodge website, it says 3.42 is standard, optional is 3.73 and 4.10.
Its not a mistake that mans best friend cannot talk.
Old 02-23-2011, 05:46 PM
Mcbride's Avatar
Rep:13
Originally Posted by Stangshcky12 View Post
3.73s and a dpf delete and you'll see plenty of power and good fuel mileage
The kit from H&S looks good for doing this.
Old 02-23-2011, 05:48 PM
Mcbride's Avatar
Rep:13
Originally Posted by 79ta View Post
I agree 100%. I've done it and get 20+ mpg with unbelievable power. Don't forget, you will need a tuner with the dpf delete.
I plan on doing it after a while, but not too new, just incase i need warranty work done.
But if its a good truck after say 8 or 10 months i plan to do the delete.
Old 02-23-2011, 10:14 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Stock 6.7s with 3.42 are complete dogs. I went to load the skid steer onto the trailer and the trailer alone (3k lbs) started pushing the truck down the driveway while it was parked in gear with the emergency brake on. Never did pull it before the dpf delete but western pa hills and 12k lbs I was impressed, even with 3.42s. Usually pull it with a 5.9 with 3.73s or an International 4600
Old 02-24-2011, 10:30 AM
79ta 79ta is offline
79ta is on a distinguished road
You wont regret doing the deletes and I too waited a while before taking the plunge, just in case something were to happen. After the j35 update and 1500+ miles, I decided to go ahead with my plans and my thinking was to delete the truck early in its life to avoid egr/dpf/turbo issues that I have heard so much about. Almost 2k on the deletes and no problems.
Old 02-24-2011, 08:01 PM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
Although a dpf delete will up the power are you concerned about warranty? Honestly if you stay around 60mph I cant see you losing that much mpgs. Id be more concerned if I bought a truck and couldnt tow my load well than if I bought a truck and got crappier mpgs than expected my .02
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 02-24-2011, 09:43 PM
Color: Mineral Gray
Rep:177
Only warranty work I had done in 60k miles was for dpf related problems
Having other trucks I never did tow with the dpf because of that little scare, now it tows great and gets good mpg's
I can also tell you you can run off road fuel fine without the dpf (check engine light with the dpf)
Old 02-25-2011, 07:42 AM
I only deleted the dpf and cat but left the egr system intact, just unplugged. I can return the truck to stock in about 90 minutes so its not too bad. The best I could get was 16.5 mpg with the stock motor and that was having a cold air intake & 4" tailpipe installed. I added 2 to 5 mpg with the dpf & tuner and the oil stays much cleaner. The truck just runs so much better. Not really concerned about warranty work but if something serious happens I will change it back and take it in. Just like stangshcky12 said, most warranty work is emissions related.
Old 02-25-2011, 09:34 AM
Resident Technician
Rep:1909
The info I posted is straight from the Chrysler service info specs. Looks like one of them is dead wrong (can't say I'd be surprised to find out the service info is wrong since I've found errors in it before).
Old 02-25-2011, 03:05 PM
Deleting was a personal preference for me and isn't for everyone. I did it to increase the trucks longevity as I will keep this truck for 15+ years and didn't want to spend any time at the stealership. We dont have emissions in our state (yet) for diesels so it was an easy choice and by not deleting the egr, anyone who looks under the hood will see nothing out of the ordinary. I am thinking about making a dpf/cat look-a-like to clamp/strap around the exhaust for a stock look if emissions were to start here just in case I get stopped.
Rear Diff Recall #10V656000 LineCutter 2011 Dodge Ram Forum 40 04-02-2011 01:17 PM
45RFE sensors and rear gear change partymn Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 11-28-2010 08:45 AM
1st and 2nd gear WHINE JakeRam02 4.7L PowerTech V8 Specific Topics 2 09-21-2010 12:02 PM
Backlash setting ccdelay 5.2L V8 Specific Topics 1 09-06-2010 01:02 PM
Gear Ratio and Diff type nitrousjunky Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 12-22-2009 07:03 PM
