Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 02-21-2011, 11:24 PM
kevinph kevinph is offline
Vehicle: 2004 Dodge Ram
Color: silver
kevinph is on a distinguished road
Default Timing Chain Slack 4.7L
I am diagnosing a load clacking noise from the right (passenger side) of the head. Local mechanic and I thought it might be a bad tensioner.
I took of the right valve cover and there is a lot of slack between the chain and the chain guide at the top of cam gear. Almost a full tooth worth. The chain is tight against the tensioner arm on the bottom of the cam gear.
Could the chain have slipped a tooth? Should there be any slack at the top of the cam gear?
Any help is appreciated. I am comfortable with working on engines, but have never worked on an overhead cam engine.
Note: Mechanic thought the engine might be "sludged up" - no sludge present except in filler spout.
Old 02-22-2011, 12:14 AM
mark1963 mark1963 is offline
Vehicle: 2003 Dodge Ram 1500
mark1963 is on a distinguished road
Default engine sludge
i am no mechanic by far, so i can't help with your chain tensioner but i thought the same thing about the engine oil sludging at the filler spout, if you seen no sludge when you removed you valve cover yuo are good being that is where your engine sludge would start,,
good luck on the chain,!!
Old 02-22-2011, 01:13 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
this is what happened to mine
Old 02-23-2011, 08:42 AM
Color: silver
Any mechanics out there who can help with diagnosing the slack in this timing chain? I can upload pictures if it will help.
Old 02-23-2011, 11:53 AM
Resident Technician
Rep:1909
If the timing were off, you'd likely have bent intake valves since these engine have little tolerance for timing errors. A clacking noise makes me think a lash adjuster or rocker problem since loose tensioners tend to make a high speed rattle that sounds almost like a buzz. The chain can have some slack with the engine off because the tensioners are hydraulic.
Old 02-23-2011, 08:43 PM
Color: silver
I have the valve cover off. Any problem with oiling if I run it with the valve cover off to see if the chain tightens up?
I am concerned because the slack is on the upper part of the chain (against the guide) not on the bottom of the chain next to the tensioner.
Old 02-26-2011, 11:51 AM
Color: silver
I ran the engine with the vlve cover off. Tensioner firmed up the chain fine. Looks like it is oiling okay at each cam lobe. There is still an ungodly clacking sound.
With the valve cover on the sound is definitely loudest at the very front of the cover. With the cover off it is hard to isolate the sound to any specific cam component.
How can I test/check lash adjusters or rockers?
thanks
Old 02-26-2011, 11:59 AM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
Its a lot of work, but taking off the front timing cover will let you look at all of the timing components. Like the poster above, I had two broken chain guides, the plastic was cracked, the aluminum was fine. The dealer had one in stock, Advance had the other.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 02-26-2011, 12:02 PM
Color: Gold/Silver
One other thing; to check for correct chain position rotate the engine until the pink dots on the chain align with the circle or dot on the cam sprocket. When they do they should be facing straight up. If the chain had jumped a tooth, all of this would never line up. The manual explains this in detail, if what I'm saying is confusing.
Old 02-26-2011, 12:03 PM
Resident Technician
Rep:1909
Clacking makes me think it's a lash adjuster. I've never seen a rocker go bad but it certainly could happen. When we get a lash adjuster problem, we replace them all just to be on the safe side.
Head Gasket Replacement 4.7L jaymiller 4.7L PowerTech V8 Specific Topics 37 07-14-2015 03:00 PM
How to set timing GodSpeed 4.7L PowerTech V8 Specific Topics 5 10-21-2014 01:06 PM
Double roller timing chain? kicknjeep Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 8 01-15-2011 07:22 PM
Any mtc required for timing chain? Turbovsix 2010 Dodge Ram Forum 6 09-09-2010 01:43 PM
what is the dealer time for a timing chain case inner gasket change ape stit Cummins Diesel Specific Topics 5 05-26-2010 11:28 AM
