Old 02-21-2011, 10:30 PM
steelman512 steelman512 is offline
Vehicle: 2002 Dodge Ram 1500 SLT 5.9L
Rep:27
steelman512 is on a distinguished road
Default how to add a rear block?
So I got my rough country 3" suspension lift the other day and managed to get the coil springs and all 4 shocks on. I was wondering if anyone knows the best way to add the rear blocks? I planned on unbolting the leaf spring u bolts and using a jack and jack stands to lift the truck under the springs to create a gap, assuming the wheels and axle will stay put on the ground, then slipping the blocks in. Any thoughts?
Old 02-21-2011, 10:34 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Your best bet is a two point lift and get it off the ground a little then use your jack stands for the axle
Old 02-24-2011, 03:07 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
I'm sure you're done now but I've always used the tall jackstands under the frame on each side and then used my floorjack to hold the pumpkin up. That way you can manuever the axle where you need it. I've never re-used the ubolts either. I've always cut them off and then bolted on new ones with blocks/leaf springs. Much easier than unbolting them. It's already a pain to torque them down without air tools.
By the way never said it was safe
Old 02-26-2011, 12:03 AM
Spartan7G09 Spartan7G09 is offline
Vehicle: 2011 Dodge Ram
Color: Inferno Red
Rep:30
Spartan7G09 is on a distinguished road
X2! It's a pretty simple task when you go about it this way.
How do I disable the rear sliding window. persuazion Dodge Ram General Discussion 7 03-20-2015 11:13 AM
New Rear window with defrost 05DodgeRam2500 Dodge Ram General Discussion 16 02-11-2015 05:32 PM
Feeler: 2" lift kit, Bilstein 5100's and rear bock kit (06-08 1500) ScatPak07 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 10 10-08-2010 08:25 PM
Lowering rear of truck bones64 Dodge Ram General Discussion 9 02-09-2010 09:18 AM
Rear Block... 04RAMsprt Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 01-23-2010 06:32 PM
