Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 04-15-2011, 10:04 AM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
Originally Posted by RAMING IT View Post
Im still running stock manifolds too. I have two stock precats on my Y pipe were my 02's are but the main cats gone. I got my 3" running all the way back to the stock rear corner panel. I hear that dumping them at the muffler sounds a bit more deeper?
dunno about deeper...but I can tell I piss people off passing them at WOT lol
Start up
Interstate
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
Old 04-15-2011, 12:12 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Truck sounds good! It does sound a bit deeper than mine. Was that an image of a rabbit on your dash after the "D" as one of your gears? I gotta get me a youtube acct.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 04-15-2011, 12:51 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Best for performance as far as exhaust would be true duals with x pipe, next best is true duals with H pipe, then either true duals totally separate or Y pipe are both good, Between the two, a Y pipe will provide slightly more low end and less top end, true duals not connected will provide slightly less low end than Y pipe but more top end. Pipe diameters get tricky....lol
Sean
Old 06-09-2011, 10:25 PM
Saetun's Avatar
Saetun Saetun is offline
Vehicle: 2006 Dodge Ram 1500
Rep:23
Saetun is on a distinguished road
I know this is an old thread, but i always thought traditional thinking was that a single to dual system is just for looks. Unless you have 2 cats, downpipes, mufflers, etc... the scavenging would be nearly the same & wouldn't improve your power band whatsoever.
Old 06-10-2011, 07:58 AM
snrusnak's Avatar
Rep:1385
There's two reasons bringing the exhaust pipes together is good. 1) when the left and right banks are connected down stream in the exhaust it equalizes the pressure and the motor runs more "even" from left bank of cylinders to right bank of cylinders. 2) This is the main reason, when you take two pipes, with gases flowing through them at a certain velocity, then merge the two pipes together into one, the velocity increases, and this helps "suck" the exhaust out of the engine, increasing power potential. "Back in the day" true duals were considered the best because everything came from the factory with two undersized down pipes from the manifolds slamming into each other (not a good flowing y pipe) into a single, even more undersized, exhaust pipe. Obviously, if you take your truck and take the down pipes from the manifolds and y-pipe them into a single, half inch exhaust pipe, that will not flow well, lol. Technology and availability/ease/affordability of aftermarket thrives nowadays.
Sean
Old 06-10-2011, 12:03 PM
Saetun's Avatar
Rep:23
I'm sorry my question must've been a little ambiguous. I completely understand the purpose & benefit of a crossover on dual exhaust & how that effects scavenging. I'm wondering if there is performance advantage to adding a single to dual kit on a single exhaust setup. Basically, exhaust manifolds to single cat, single downpipe, single muffler with dual outlet and two exhaust tips. I know the kits look great, but it has always been my understanding this is a cosmetic upgrade, at least in hotrod/musclecar circles & was wondering if that was no longer considered the case.
Old 06-10-2011, 12:11 PM
snrusnak's Avatar
Rep:1385
Oh gotcha! This would not give any scavenging/performance benefits....basically same as just a single pipe all the way. Keep in mind though, you would usually have a y-pipe first where the down pipes come together, so would still benefit from that.
Sean
2010 1500 5.7L Single to Dual Exhaust plus Intake??? NewfieRam1500 Exhaust 26 04-07-2014 12:45 PM
True Dual Exhaust Bighert3rd 2011 Dodge Ram Forum 6 02-15-2011 03:55 PM
True Dual Exhaust System Bigman 5.7L (345 cu in) HEMI V8 Specific Topics 15 12-01-2010 07:39 AM
Single out or dual out? bones64 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 06-14-2010 09:07 PM
Single out to Dual out on ST without cutout bumper. StoneyWV Dodge Ram General Discussion 4 02-20-2010 03:25 PM
