Old 02-23-2011, 11:55 AM
dano335
Default Rear Axle Bearing 1999 Ram
I would appreciate any information on how to replace the rear axle bearing on my '99 Ram 1500 4wd. Also, are there any special tools required? When I removed the rear hub, I found grease all around the shoes and hub. Also, I have very slight up / down movement of the axle.
Thanks,
DanO
Old 02-23-2011, 11:57 AM
Rep:1890
ASounds like a plain old worn out axle seal to me. If you've done them before, you should be able to handle it with no problems. The closest thing to apecial tools you need are seal removers and installers.
rear axle bearing? bigred112 5.9L V8 Specific Topics 14 02-27-2011 10:06 PM
2003 1500 rear axle richieb 5.7L V8 Specific Topics 1 09-06-2010 11:54 AM
trans grenaded or/and rear axle imploded stray dog Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 03-25-2010 03:07 AM
dodge ram rear axle 99 ram slt Dodge Ram General Discussion 1 12-18-2009 08:38 AM
1999 Dodge Ram 2500 4x4 rear driveline vibration Wilkinson Mike Newbie Checkin! 4 07-08-2009 04:37 PM
