ZDOG
Old 02-23-2011, 10:16 PM
quadbob's Avatar
quadbob quadbob is offline
Rep:67
quadbob will become famous soon enough
Default Anyone change dash/door speakers yet?
I am getting ready to order upgraded speakers for my 2010 Crew Cab.
Just wanted to see if there are any "Suprises" that I should be aware of when removing the old & installing the new speakers.
According to Crutchfield all of the 10 Ram speakers are 6 1/2". Is this correct?
Thanks.................
Old 02-23-2011, 10:47 PM
Jack Nasty Jack Nasty is offline
Vehicle: 2010 Ram 1500 4x4
Color: Mineral Gray
Jack Nasty is on a distinguished road
Doors are 6x9 and dash are 3.5's. The 6x9's I chose fit, but they are SNUG with the panel, depth was no problem. 3.5's have little/no slack in the factory wire (if you use it), you really need an extra arm to make it easy. I ordered the factory plug adapter and it did not fit, they sent me the ones for the doors. If you get the correct adapter you would have plenty of room.
Tony
Old 02-24-2011, 02:30 AM
heavyzee heavyzee is offline
Vehicle: 2010 ram
Rep:65
heavyzee will become famous soon enough
Tony
which 6x9's do you have??
Old 02-24-2011, 11:02 AM
BigHorn2010 BigHorn2010 is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Trim Level: SLT Big Horn
BigHorn2010 is on a distinguished road
I just replaced all 6 speakers in my 2010 Crew Cab. I went with Polks all around. 3.5" in the dash (I ran new wire for those) and 6x9's in all four doors and used the factory wire. I also replaced the head unit and added a 4 channel amp which really brings the polks to life.
Old 02-24-2011, 03:24 PM
ABD26's Avatar
ABD26 ABD26 is offline
Vehicle: 2010 Dodge Ram 5.7 Crew 4X4
Rep:176
ABD26 has a spectacular aura aboutABD26 has a spectacular aura about
Is it worth it? What are you accomplishing by switching out the speakers? How much better is the sound?
"A two-year-old is kind of like having a blender, but you don't have a top for it."- J. Seinfeld
Old 02-24-2011, 10:57 PM
Color: Mineral Gray
Rockford Fosgate
In terms of car audio, $1000 is not a lot, but that is what I spent on mine and it is Sooooooooo much better. Nobody can tell you "how much better" upgrading components will make your system sound, you should find someone who has an aftermarket system that has been installed properly and tuned to a taste similar to yours, then you can see for yourself.
Tony
Old 02-25-2011, 10:52 AM
bmbaker51's Avatar
bmbaker51 bmbaker51 is offline
bmbaker51 is on a distinguished road
I did Boston Acoustic 6x9 in all four doors, boston amp under the drivers seat and a boston sub under the passenger's side back seat. Most Boston speakers are very shallow so they fit in the door very easily but they still give tremendous clarity.
The sub was added just for a little extra kick but i never have it more than half way up. I had a custom box built for under the seat to house the sub and sprayed it with rhino liner. No rattles or anything in the truck which i was pleased with. But everything sounds much more....musical? i guess would be the word choice? the stock speakers would kind of mush everything together. The ones i put in are great and you can actually hear just about everything going on in the song. Would def. recommend similar setup.
BURN OUT, NOT FADE AWAY!
oil change warning revisited.... muskybait 2010 Dodge Ram Forum 11 05-26-2011 10:32 PM
Qucik change oil valve-check!.. - messy oil filter change - options ? alecmcmahon 2010 Dodge Ram Forum 14 03-05-2011 07:19 PM
Oil change due too early, too often? kraftfahrer 5.7L (345 cu in) HEMI V8 Specific Topics 3 01-31-2011 03:02 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
Oil Change Message clatla 2010 Dodge Ram Forum 24 08-21-2010 03:20 AM
