Old 02-23-2011, 11:20 PM
farmall farmall is offline
Vehicle: 2003 3500 QC diesel
Color: Patriot blue
farmall is on a distinguished road
Default 3500 rear ratio opinions
Hello guys,
I currently have a 2003 quad cab 3500 4x4 single rear wheel, short bed with diesel, 6 speed and 3:73 gears. I am interested in getting a crew cab dually 4x4 with diesel and 6 speed manual transmission. I can't really decide what gear ratio to get, 3:73 or 3:42. My current 3:73 work great and always have plenty of power. I get great mileage. i was thinking about 3:42 to get better mileage because I understand that these higher HP engines (mine only has the 305hp/555trq engine). I will be pulling the following:nothing, or 16ft enclosed trailer or 40 ft 5th wheel camper (about 13000lbs) Does anyone have any opinions?
Thanks in advance.
Old 02-24-2011, 09:35 AM
Rep:1845
3.42:1 gears are NOT offered in any of the Rams. The numerically lowest gearset you can get is 3.73:1.
Old 02-24-2011, 09:13 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
With the 3.73s being a no charge upgrade from the 3.42s I'd go with the 3.73s. Just in case you end up going with a bigger tire down the line you won't have to worry about a gear swap.
Old 02-24-2011, 09:46 PM
Color: Patriot blue
According to all of the info I have seen, 3:42 gears are available, in a 2011 at least.
I am not really the type to go changing tire size so I am not concerned about that. I am really looking to get the best fuel mileage, without sacrificing "towing power". I have the 3:73 and get great milegae and power. I am just wondering if I can get better mileage with the 3:42 but still have good pulling power.
Does anyone have this combo that could give me some input?
Old 02-24-2011, 10:00 PM
CHVYKLR's Avatar
Rep:252
I saw the gears available on the website where you build your own truck too.
If bigger tires aren't in the plans the 3.42 would prob be your best bet....especially since you'll have 800 ft lbs of torque available!
If you know what ratio 6th gear is on that manual you can figure out the rpm difference here. Use the second one down titled "for specific transmission ratio."
http://www.ringpinion.com/Calc_RPM.aspx
Old 02-24-2011, 10:12 PM
Color: Patriot blue
Wow! 800? Is that right? I must have missed that.
Old 02-24-2011, 10:39 PM
CHVYKLR's Avatar
Rep:252
yeah man. here's a link.
http://www.ramtrucks.com/en/2011/ram...ty/powertrain/
edit...that is with the auto. the manual has 650 ft lbs. sorry about that. maybe choose the auto over the 6-speed???
Old 02-25-2011, 10:21 AM
Color: Patriot blue
Man, that is impressive. I really love my manual but I might have to reconsider???
Old 02-25-2011, 06:32 PM
CHVYKLR's Avatar
Rep:252
hell yeah. who doesn't want 800 ft lbs of torque and with the auto you can still eat your fries and drive...lol.
Old 03-04-2011, 06:37 PM
knsram knsram is offline
Vehicle: 2011 Dodge Ram 3500 Crew Cab
Trim Level: Laramie 4x4, 3.73gr
Color: Deep Pearl Red
Rep:20
knsram is on a distinguished road
Lightbulb
If you look at Ddoge's website and go to 2011 Dodge Ram trucks 2500 & 3500 specs page you will find that all 2500's come standard with 3.73 and 3500's come standard with 3.42. Which to me seems a little backwards since most people gettin 3/4 and 1 tons are for hauling and pulling and would thus be better equipped with the lower gear ratios. You can opt for either the 3.42 or 3.73 ratio with out additional charge, but not for the 4.10. believe most owners will never really notice any significant difference in MPG unless making extreem changes in gear ratios, such as 3.42 to 4.10 as well with tire sizes.
knsram
2011 Dodge Ram 3500 Laramie Crew Cab 4WD Dually LB
Stock gear ratio in a 98 4X4 rear end. Quiet Lunatic 5.2L V8 Specific Topics 2 01-07-2013 01:21 AM
Rear axle ratio choice on 2011 Ram Hemi postman Newbie Checkin! 15 09-06-2010 02:05 PM
Rear Axle Ratio lt173 2010 Dodge Ram Forum 4 08-13-2010 10:00 PM
Rear ratio new dodge man Dodge Ram General Discussion 8 10-24-2009 09:36 AM
Rear Gear Ratio ShotGunWillie 2009 Dodge Ram Forum 7 09-29-2009 10:48 PM
