Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 02-23-2011, 11:54 PM
billrath14 billrath14 is offline
Vehicle: 1992 dodge ram150
Trim Level: le
Color: blue
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
billrath14 is on a distinguished road
Default peddle slowly drops
I have a 92 150. When I put the brakes on I got good peddle but if I sit with my foot on it, it will slowly drop down, The "anti lock " light will come on also. I have put a rebuilt master cylinder on along with a new power booster, new pads and shoes. I have also purged the lines. both of the problems may not be connected because the antilock light comes on when I start the truck then goes out. And some times it will stay off when I brake then let off befor the peddle drops very far.
Thanks in-advance Bill
Old 02-24-2011, 09:42 AM
Resident Technician
Rep:1909
My first suspicion would be the master cylinder.
Old 03-30-2011, 10:53 PM
Trim Level: le
Color: blue
replaced the master cylinder and bleed the brakes 3 times. The problem is still there. The peddle has 4 inches of travel before it starts slowing down the truck. it also fells mushy under "hard" braking, I can not get this truck to stop fast like it should.
Old 03-31-2011, 05:54 PM
There's still a pressure problem and I'd suspect one of the slave cylinders on the wheels aren't working. They corrode and/or the caps and plungers aren't moving properly.
I'm slowly making it mine, whatcha think... js1977 Dodge Ram Pictures - Photos 90 02-04-2012 01:17 PM
SRT Andy SLOWLY crept toward 1,000 posts! iRESQu Off Topic Discussion 25 11-11-2010 06:42 AM
Brake peddle squeek? UnLiMiTeD 2010 Dodge Ram Forum 26 10-05-2010 01:35 PM
reqesting pics of 4/6 drops! dmopar74 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 08-06-2010 08:24 PM
Oil pressure drops to zero jeff pearson 4.7L PowerTech V8 Specific Topics 11 07-11-2010 03:45 AM
