Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Old 03-30-2011, 05:00 PM
kidyounger kidyounger is offline
Vehicle: 1998 dodge
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
kidyounger is on a distinguished road
Default rotors
how do you remove the rotors on a 98 dodge 4x4 and what are the specs on turning rotors?
Old 03-30-2011, 05:07 PM
Rep:1845
REMOVAL
  1. Raise and support vehicle.
  2. Remove wheel and tire assembly.
  3. Remove hub extension mounting nuts and remove the extension from the rotor if equipped.
  4. Remove brake caliper.
  5. Remove the cotter pin and hub nut from the axle shaft.
  6. Disconnect the ABS wheel speed sensor wire from under the hood. Remove sensor wire from the frame and steering knuckle.
  7. Remove hub/bearing mounting bolts from inboard side of steering knuckle.
  8. Remove rotor hub/bearing assembly, brake shield and spacer from the steering knuckle NOTE: If rotor hub assembly will not come out of the knuckle, use Puller C-844 with extra Puller Leg C-884-1 to remove the remove the assembly.
  9. Press out the wheel studs/hub extension studs and separate the rotor from the hub.
Discard spec is 1.269 in for the LD and 1.521 for the HD brakes.
Brake rotors arsonhntr Suspension 5 02-28-2011 12:09 AM
Best Dimpled and Slotted Rotors??? Quiet Lunatic Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 21 09-13-2010 12:32 PM
Mopar rotors Kens04 Suspension 4 05-07-2010 11:19 PM
Free LH Body Front Brake Rotors RamTech Other Vehicle Discussion 1 01-20-2010 10:49 AM
Pads and rotors jjhwick119 Brakes 9 12-07-2009 02:49 PM
