Old 02-24-2011, 12:40 AM
2010NebBigHorn's Avatar
2010NebBigHorn 2010NebBigHorn is offline
Vehicle: 2012 Dodge Ram
2010NebBigHorn is on a distinguished road
Default Nav Install with PAC C2R-CHY4
I an installing a JVC in dash NAV unit from crutchfield and got the PAC C2R-CHY4 wiring harness for it. It is supposed to be delivered via UPS tomorrow and I am wanting to make the install as quick and easy as possible. Does anyone know if the speed sensor wire is plug and play or will I have to try and locate it behind the dash and splice into it?
If I do have to locate it, does anyone know where it is located at?
Thanks
Mopar Leveling Kit, N-Fab Steps, 295\60\20 Trail Grapplers, K&N CAI, Hypertech Speedo Calibrator
Old 02-24-2011, 04:38 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
You should repost this in the audio section, hopefully someone will see it and help you out!
Old 02-24-2011, 11:53 PM
slickram slickram is offline
Vehicle: 2010 Ram
slickram is on a distinguished road
Thanks
I just installed a Sony XNV 72bt on my truck and after some research I was told to leave the speed wire out because the antenna for the gps will give your unit the speed info. It works just fine for me, my navy tells me the exact speed the truck is moving.. hope this helps good luck
How to set timing GodSpeed 4.7L PowerTech V8 Specific Topics 5 10-21-2014 01:06 PM
HID Install 09/10 RAMS doz Custom Dodge Ram Interior and Exterior Lighting 14 03-20-2011 02:28 AM
Amp Install Complete - with Pics colingibb Custom Dodge Ram Interior Modifications - Custom Audio / Video 20 01-25-2011 01:35 AM
Computer won't install device driver? wickedpissahtruck Diablo Predator Questions & Info! 5 11-08-2010 06:28 PM
My 2nd Mod, TRX Skid Plates - An Easy Install Brute 2009 Dodge Ram Forum 4 03-02-2010 01:01 PM
