Old 03-28-2011, 04:46 PM
rjr1214 rjr1214 is offline
Vehicle: 2004 Dodge Ram Cummins
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
rjr1214 is on a distinguished road
Default Trailer turn signal issue
I have a problem with the trailer wiring coming from my truck. When I'm plugged in I get no left turn signal at the trailer. I checked the fuse, and it is ok. I used a multimeter to check the 7-pin round plug on the truck and it is not getting any power to the left turn. I checked the wires coming out of the trailer harness and leading to the front of the truck and could see no obvious failures there, but the wiring bundle runs along the drivers side frame where it meets up with some other wire bundles along the way and then up into the left fender where I can no longer see it...assuming it runs into the bottom of the fuse box there. Any ideas, experience with this type of issue?
Old 03-28-2011, 04:51 PM
Rep:1885
Here's a diagram that may help your diagnosis.
Old 03-28-2011, 06:16 PM
Do you know what color wire should be feeding the left turn signal for the trailer adapter? this would help me to follow it.
Old 03-28-2011, 07:09 PM
Rep:1885
The yellow wire is for the left turn/stop lamp. Circuit 673 in the diagram above.
Old 03-28-2011, 07:50 PM
So after spending way too much time jerking around under the truck and fixing some wires/splices that were bad, I made a breakthrough. After repeatedly checking fuses I turned on my right turn signal (this one works on the trailer) and listened to the relay in the IPM (fuse box) and then turned the left signal and listened to that relay... has a funny sounding "click - donk" rather than "click - click." After doing a google search for '2004 dodge ram trailer tow left turn relay' I have verified that these trucks are actually pieces of crap and the relay is integrated into IPM, thus requiring replacement of a several hundred dollar part that I can't locate... not even on crapslerpartcenter. Now this Dodge is turning into a Chevy and I knew I should have bought a Titan, but thought the diesel would be better.
Old 03-29-2011, 11:45 AM
Arctic Owl's Avatar
Arctic Owl Arctic Owl is offline
Vehicle: 2011 Ram 1500 Crew Cab
Color: Medium Grey
Rep:38
Arctic Owl is on a distinguished road
Sorry to highjack this thread, but;
Hey Ramtech. Do you know were the power source is for the rear 12v Power Outlet in a 2010 3500 Laramie? I have checked all the fuses under the hood & they are OK. I do not have any power at the plugin. Is there another fuse system inside the truck? Yes I have made sure the key is on before checking.
Reg
Old 03-29-2011, 11:54 AM
Rep:1885
Power comes from the TIPM under the hood. Since it's under warranty, let the dealer handle the problem.
Old 03-29-2011, 12:01 PM
Arctic Owl's Avatar
Color: Medium Grey
Rep:38
Thanks for the quick reply Ramtech. Guess it may mean replacement of a part or just a reflash?
Reg
Old 03-29-2011, 12:09 PM
Rep:1885
TIPM problems usually require replacement of the module itself.
Problems with my turn signal lights. kjtc6 Electrical 20 06-06-2013 08:02 PM
Turn Signal Issue jayhkr Electrical 13 07-29-2012 10:24 PM
Trailer turn signal not working EBK142 Electrical 10 03-19-2012 07:52 PM
Turn signal acting off jayhkr Electrical 5 07-29-2011 03:59 PM
right trailer turn signal wire redeye4u Electrical 27 05-27-2011 10:57 PM
