2005 1500 Tire question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-24-2011, 02:18 PM
LCC Chrome Hemi LCC Chrome Hemi is offline
Vehicle: 2005 Dodge Ram 1500 Hemi
Color: Dark Blue
LCC Chrome Hemi is on a distinguished road
Default 2005 1500 Tire question
Whats up everyone? I currently run a R17 rim size. Whats the tallest tires that can go on these without a lift? Also is it possible to put 20" rims on a 05' 1500 without a lift?
Cheers!
Yup, I am gonna pass you on this snowy road!....MOVE!...:)
Old 02-24-2011, 03:53 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I would stick to a 33" tire without any lift and yes you can put 20" rims on, the stock ones came with 20's as well as the 17's
Old 02-24-2011, 04:01 PM
Color: Dark Blue
Thanks for the quick reply 916Timmy. Do you know if I went with 20" with 33's how much taller would that make the truck over a R17 w/285?
Old 02-27-2011, 12:17 AM
Ostranza's Avatar
Ostranza Ostranza is offline
Vehicle: 2005 Dodge Ram 3500 QuadCab
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
Rep:68
Ostranza will become famous soon enough
285 is the width in mm. What is the next number? That is the number that is a percentage of the width which you'll multiply by two and add the rim height for total tire Outer Diameter tire size....a lot of work I know. I hate metric. Go to www.1010tires.com for a tire calculator but 33" tires work with stock 20s or 17s with no problem on a 2wd or 4x4 Ram.
Old 02-27-2011, 12:21 AM
Ostranza's Avatar
Rep:68
I have seen people put a 35x12.5 tire on stock rims with a little rubbing on hard crank turns...on a 2wd....3rd generation.
Kinda crazy.
Where do you stand in the 1/4 chefred112 Drag Racing Discussion 162 08-16-2012 07:25 PM
VERY technical question about wheel and tire sizes.. curt4816 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 13 05-03-2011 01:50 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
2005 ram 1500 qc/sb body lift on a 03.. 4doordodge4life Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 11-02-2009 09:34 PM
Questions bout lift and tire size for 1500 Dcox88 Newbie Checkin! 7 02-02-2009 10:12 PM
