Dodge Ram Forum - Ram Forums and Owners Club! - Dodge Truck Forum
Go Back   Dodge Ram Forum - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram General Discussion
Dodge Ram Accessories!
Old 02-25-2011, 12:06 PM
DaSOB's Avatar
DaSOB DaSOB is offline
Vehicle: 1998 Dodge Ram Ext Cab
Color: Light Driftwood Satin Glow
Rep:38
DaSOB is on a distinguished road
Default My steering column woes and how I cured them
Some of y'all have seen my threads grousing about the problems I was having with noise and slack in my steering. Well, I fixed 'em without putting in a new column, and I'm gonna show y'all what I found for y'all's future reference.
I had had a loud scraping noise in my steering column when I would turn it lock to lock. Didn't hear it with small movements in normal driving, but hauling on the wheel to park my ole Ram elicited noises that sounded a lot like when the dentist is really scraping your teeth. I went through manuals, sites, mechanics, tarot cards and the Dali Lama trying to get to the source of the scrape. I tore down the column as far as I could go, but could only determine that the scraping was somehow associated with the shift collar in the column - I could feel the scraping in the selector lever when I would turn the wheel. I did the spray 'n' pray thing with probably a couple of quarts of various spray lubes through every opening in the column I could find. Nada. Time for another beer.
I also had some wander in the steering - made it hard to nap on long trips because I had to stay awake and keep it between the ditches.
I finally broke down and ordered a new column from Columns Galore - very nice folks, highly recommended. Anyway a day or two later I was screwing around under the dash and found that the lower end of the column is covered by a large-mesh plate. I shot a few blasts of teflon lube in there... VOILA! The grinding noise went away!
I called Columns Galore and canceled the order, and they were very gracious.
OK, on to the slack. I have already posted about the OEM intermediate shaft so I won't go into that here. Put in the Borgeson - world of difference, but still a little sloppy.
A while back I had bought an aftermarket replacement lower bushing from Rock Solid Ram Truck Steering, so I decided I might as well go ahead and install it. It's a pretty straightforward and simple fix - the most difficult part was working around the vacuum booster to get the old bushing out.
OK, installed that, and now my steering is tighter than the bark on a tree. Beauty!
Now, about that scraping noise. Have a look at these two pics:
This is the culprit. There is a bearing pressed into this bushing, and that bearing was completely shot. I can rotate the inner race with my finger, and it feels like the thing is full of sand. In the closeup you can see that some of the solvent I used to clean the bushing is in the actual race, and that it is full of rust. When I had hosed the lower end of the column through the mesh, enough lube had run down into the bearing to quieten it.
The reason I was feeling the scrape in the selector lever is that this bushing seats through the shift collar, and the scraping was being conducted up to the selector lever because of that.
But now that I have the new bushing and the new intermediate shaft, I have nice tight steering and no noise - my boy is like a new truck!
So y'all might want to file this tidbit for future reference. My suggestion is that if you haven't already, get a Rock Solid bushing and replace the OEM one. It's vastly superior and it won't wear out.
Ah Luv Muh Truck!!
Old 02-25-2011, 12:30 PM
NewMexicoRam NewMexicoRam is offline
Vehicle: 2010 Dodge Ram 1500 4WD
Color: Gray
NewMexicoRam is on a distinguished road
Good info. I'll have to tell a friend . He was saying something along the way of which you wrote.
Freedom has a flavor the protected will never know. Vietnam # 10 G.I. '66-'67
Old 02-25-2011, 12:31 PM
Rep:1601
Great write up that I'm sure will be useful to others.
RamForumz.com | Dodge Ram Forum | Dodge Ram Forums | Dodge Ram Performance | Dodge Ram Accessories | Custom Dodge Ram | Dodge Truck Forum | Ram Truck Forum
Old 02-25-2011, 07:04 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Great info, thanks. Now I hope I never have to use it!
www.howtobeatcraigslist.cu.cc - for posting dangers & secrets
Old 02-25-2011, 11:25 PM
DaSOB's Avatar
Rep:38
Ram15002ndgen, I hope you don't too. But if you do, it's a lot easier than it may sound right at first. My truck is a 98, so we have the same exact steering column (assuming that yours is auto on the tree), and like I mentioned the hardest part really was working around the vacuum booster to get the old bushing out.
I knocked the bearing out of the old bushing and disassembled it (actually, it fell out in sections). I'll post some pics of the pieces/parts in a couple of days (I'm away from my home 20 right now). It's a purpose-made pre-loaded little bugger, probably not something you'd be able to pick up at your local bearing supply house. But in light of the aftermarket bushing, that's academic. The Rock Solid bushing has the bearing beat hands down, and it's idiot-proof. I mean, heck, even I put it in and got it to work!!
I drove the truck a couple hundred miles today from my home in Baton Rouge to my Mom's home in north Louisiana, and I swear it was like driving a new truck. Nice tight steering - I found myself over-correcting some at first after having become used to having to think ahead of the steering wheel.
I'm going to replace the track bar bushings also, just because it's time. That will help with front-end stability and make the steering feel tighter and more responsive.
Ah Luv Muh Truck!!
Cured my steering column woes! DaSOB Dodge Ram General Discussion 1 02-19-2011 03:58 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
CLUBS MOPAR NATION Deep South Mopars Great PlainZ Modern Mopars JAM
