Old 02-25-2011, 01:22 PM
Mikey88's Avatar
Mikey88 Mikey88 is offline
Vehicle: 2008 Ram
Trim Level: Big Horn Q/C 4X4
Color: Black Pearl
Rep:12
Mikey88 is on a distinguished road
Default tire size for 08 big horn
Hey guys, I have an 08 1500 Big Horn 4x4 Quad Cab. I have the stock 20" rims with 275/60r20's. What is this largest tire I can run with out leveling or lifting? The tire guys are saying to go 305/55r20's which is only about a 1/2" taller then my stock tires. It looks like I have lots of room to increase. I have read that the Big Horns have a heavier suspension set up, so do they ride higher than normal?
Old 02-25-2011, 01:44 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The Big Horn package is just appearance, no suspension difference. The 305's might have a slight rub, but they should work!
Old 02-25-2011, 09:33 PM
I've seen some 305/55X20's on stock setups. Only problem was a rub inside at full steering lock.
Old 02-25-2011, 09:52 PM
flip16's Avatar
flip16 flip16 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: big horn
flip16 is on a distinguished road
i just had mickey baja atz 305 55 20's installed on my truck today and i have a 2in leveling kit on my truck i would get the kit if you could swing it, about 400 installed with the alignment, i dont think the height is the issue, my tires are VERY close to touching my ball joints i could probally get away with it but im not going to risk it im going with 1/4" spacers
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Tire size? CHADDER03 Dodge Ram Wheels And Tires 7 01-24-2012 12:46 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Tire size question(Yes another one) bones06 Dodge Ram Wheels And Tires 6 02-24-2011 10:08 AM
Tire Size 01RAMguy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 04-21-2010 11:37 PM
