Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 02-25-2011, 05:31 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Default FINALLY Making the Switch to Synthetic
Title says it all. I figured since my trucks getting higher in mileage I need to start treating her nicer. I've been only running 89 and 91 octane fuel for a while, and I'm gonna make the switch over to synthetic oil.
Old 02-25-2011, 05:39 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Me too brotha!!!!! Got a surprise pm from an Amsoil dealer! I'll ask him if he can PM you too
Old 02-25-2011, 05:40 PM
jcasey10's Avatar
Rep:869
Thanks man!
Old 02-25-2011, 05:47 PM
SslagleZ28's Avatar
SslagleZ28 SslagleZ28 is offline
Rep:158
SslagleZ28 has a spectacular aura aboutSslagleZ28 has a spectacular aura about
Great news. Honestly its worth it, also throw in Lucas oil Stabilizer, its awesome as well.
Backlash
Semper FI
Old 02-25-2011, 05:54 PM
purodude's Avatar
purodude purodude is offline
Vehicle: 2012 ram 1500 crew cab
Trim Level: sport
Color: bright white
Rep:16
purodude is on a distinguished road
Me too! I got my Amsoil shipment today and can't wait to install it.
Old 02-25-2011, 06:15 PM
Trim Level: sport
Color: green
Rep:643
i am sure others know more than me,but isn't switching over to synthetic on an older truck likely to find ways to leak.
Old 02-25-2011, 06:33 PM
Butter's Avatar
Butter Butter is offline
Vehicle: 2010 Ram 1500 4x4 RC/SB
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
I think your truck will thank you in the long run! After doing a lot of reading I went with a synthetic oil on the first oil change.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 02-25-2011, 06:47 PM
Trim Level: sport
Color: green
Rep:643
i agree with synthetic in a new truck, you do see he is driving a year 2002 truck? he didn't state how many miles are on it though. i have been told there is really no benefit in changing to synthetic after 50000 mile, and when you get close to 90000 miles the thiner, more slippery oil is more likely to find ways to leak out.
Old 02-25-2011, 09:21 PM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
This is a myth. What synthetic oil WILL do is clean out any engine oil sludge in your motor. If the engine oil sludge is what was causing you to NOT have any leaks, wouldn't you want to fix it the right way in the first place by replacing whatever seal may have had a leaking problem in the first place? Synthetic oils will not cause leaks, but they may uncover a leaky seal that was covered up by sludge from dino oil.
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-25-2011, 10:58 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
+1,000,000 . couldn't say it better. for example... my 91 plymouth Acclaim 3.0l had 47k. take off oil cap and you couldn't see the valvetrain cause there was so much sludge. well, at the time, i was using regular ole dino oil. changed it every 2k. at 72k, a lil late, time to do a timing belt change. well, valve cover gaskets were leaking pretty bad. pull covers off and my boss (when i was turning wrenches part time) took a look and his words were,"dang Z, you could eat off that valvetrain it's so clean!" well, changed gaskets and belt, and started using synthetic oil. i continued to use synth up until 157k (when the water pump let go, took out the timing belt and blew coolant all over). there were no leaks relating to the top half of the engine. not the case for the bottom. leaked quite a bit cause it was never touched.
i use synth in both vehicles. AMSOIL OE in the van (only 25k miles) and their 25k synth for the truck (103k). love it and ain't goin back
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Drivers door lock switch......... bigdaddyII Electrical 9 01-25-2011 12:09 PM
horn separate switch dead short..help! String13 Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 12-31-2010 10:20 AM
When to switch to synthetic kevind3 Oil Change 34 11-13-2010 06:25 PM
When to Make the Switch to Synthetic? tjcin 2009 Dodge Ram Forum 27 10-05-2009 10:46 PM
