Old 03-07-2011, 04:52 PM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
Originally Posted by Luke Coulis View Post
Okay so today I went out, tried it again and nothing just like the battery was dead. So I went to the battery checked the terminals didn't seem loose so I moved the battery and I heard it click on. Turned the key and within half a turn it fired right up. Soo long story short could this be a bad ground or does none of this make sense.....?
OK, what exactly did you hear CLICK ON when you moved the battery?
Old 03-07-2011, 06:16 PM
Luke Coulis Luke Coulis is offline
Vehicle: 1998 dodge ram 1500
Luke Coulis is on a distinguished road
Okay let me clear things up. First off sorry for all the confusion. So I had a bad ground fixed that. Still not the problem. Really nothing to do with it. When it's raining or even damp out it just turns over with no problems just won't fire. I've changed the distributor cap and rotor. Still no help. As soon as it dryes out it fires right up. I'm at a loss now. Could it be the coil? What could be getting damp or wet just sitting there? I'm at a total loss. Thank you all for being so patient and putting up with me.
98 Ram 1500 4x4-9" of lift, 35-12.50-15 mts, 318 Custom frt & rr bumpers, And lots of rust
Old 03-07-2011, 07:07 PM
Color: Blue
Rep:55
The coil would be the next cheap thing to replace. Change the coil wire also.
Old 03-07-2011, 07:42 PM
Okay I got ne plugs and wires so that's next. Thanks for the help I'll keep you all posted.
Old 04-20-2011, 08:47 AM
jaidenwarren's Avatar
jaidenwarren jaidenwarren is offline
Vehicle: 1996 dodge ram 2wd ext cab
Color: black and white
jaidenwarren is on a distinguished road
Any updates on your starting issue yet. I'm having the same issue.
DubDin Navi/Custom sub centerseat/10k hid kit/3500rear wheel cylinders/2500calipers/14x3 cai
Old 04-20-2011, 03:26 PM
Tnic Tnic is offline
Vehicle: 1997 Ram 1500
Trim Level: Laramie SLT 4x4
Tnic is on a distinguished road
You know, if you spritz the wires and other ignition components with a spray bottle of water (AT NIGHT) then start it up (if you can) where ever the sparks are coming from is usually the problem child.
Failing that just hose it down with WD (WATER DISPLACING) 40 before an expected rain event, or after if you forget or get caught by surprise.
I had the same problem on my Jetta and the WD40 worked every time.
Old 04-22-2011, 02:30 AM
Irishpride413's Avatar
Irishpride413 Irishpride413 is offline
Vehicle: 1997 dodge ram 1500
Trim Level: Base model 1500
Rep:22
Irishpride413 is on a distinguished road
youre runnin low on blinker fluid hey...try that they sell some here http://kalecoauto.com/index.php?main...&products_id=6...
nah just messin with ya bro. my truck was doing it to and i changed the neutral safety switch and it hasnt had a problem since. it did it one other time and it turned out to be the coil. same thing was happening on my buddies 5.2L jeep and it was a coil so id say start there.
Old 04-25-2011, 06:17 PM
So after plugs wires cap and rotor and a few hours of driving when the weather was better I haven't had a problem in a month. And believe me it's been a rainy one. So I don't know the actual issue but it's all good now.
My truck has trouble starting... no one can figure out problem Pork Chop 3.7L PowerTech V6 Specific Topics 15 05-14-2011 09:14 PM
truck having trouble running after start Chip Dodge Ram General Discussion 5 12-29-2010 07:56 AM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
Stalling Truck after selecting Drive teebonedhell72 V10 Specific Topics 17 01-20-2010 12:51 PM
on start up truck always starts at high RPMs hemiv8dodgeram1500 Dodge Ram General Discussion 12 01-15-2010 10:37 PM
