Old 02-26-2011, 01:39 PM
nbh40 nbh40 is offline
Vehicle: 2003 Dodge Ram 1500
Color: Gray
nbh40 is on a distinguished road
Default Rear Interior Light Swap
First of many newbie questions. Before I go crazy on the interior lighting I want to do a simple change to rear interior light on an 03 quad cab.
Unless I am being stupid, I cannot switch the rear interior light on/off without switching front map lights on.
I want to change out rear interior light for a switchable one, has anyone done this? I have 3 kids and they often want rear light on, but only way to switch it is with the front light cluster dial - then the front maps come on as well.
Very electrically/mechanical minded, just wondered if there is a drop-in light.
Thanks
Old 02-26-2011, 08:12 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
have you considered some sort of battery powered portable lights? something along the lines of the "tap lights"
This might solve you problem for you, without getting all drastic.
Otherwise I'd suggest doing a search at your favorite accessories store for a dome light or something similar and go from there
good luck
Exco
Bill
Old 02-27-2011, 01:38 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
when the ds doesn't light up the back, it's a 3 dollar flashlight...
New Rear window with defrost 05DodgeRam2500 Dodge Ram General Discussion 13 11-20-2010 11:17 AM
Rear end swap 98Rammer 5.2L V8 Specific Topics 4 09-07-2010 02:18 AM
rear end swap jennsteve0907 Suspension 0 07-27-2010 05:04 PM
Rear end gear swap?? ScatPackRam Dodge Ram General Discussion 6 08-04-2009 08:08 PM
rear axle swap satcombinky Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 05-30-2009 11:45 PM
