Old 02-26-2011, 07:22 PM
1stdodgeram 1stdodgeram is offline
Vehicle: 1997 dodge ram
Trim Level: larime edition
Color: silver
1stdodgeram is on a distinguished road
Default Steerig rack
Hey guys I tried to update my last post but couldnt figure out how to edit the title so sorry for a new thread
I took my ram to a place called tanner 4wd here i colorado sprig and they did find the problems that the other shops couldnt
They said my steering componets are shot, So im going to replace the entire steering rack, Ball joints, Tie rods...
They also said my rear diff is pretty weak and it needs to be replaced along with the gears, And its exspesive, How hard is it to replace the diff i these trucks....
Old 02-26-2011, 09:24 PM
Whats wrong with the rear diff ?
Old 02-26-2011, 10:47 PM
Color: silver
Honeslty im not sure the mechanic just told me the rear diff is weak and the gears also need to be replaced, I have a vibration and humm when slowing down or coasting and he said it was from the rear diff allthough I feel the vibration under my feet
Old 02-26-2011, 11:40 PM
Rep:2657
sounds like the shims are not right, either missing or installed wrong
If your gears teeth are sharp, instead of blunt like they should be, it is time for a replacement
just remember, if you need to replace the gears, it is a chance to choose the ratio that you really want, they all cost close to the same
there are several parts in the pumpkin,, this is what it looks like
http://www.google.com/imgres?imgurl=...ed=0CFIQ9QEwBA
here are some pix of good & bad differentials
Old 02-27-2011, 07:37 AM
Rep:1885
I would ask how exactly one tests for a "weak diff". I smell a rat here.
Old 02-27-2011, 03:20 PM
Color: silver
Im not sure I was watching the tech and he was playing with the driveshaft the enters the rear diff the didnt take any covers off, and he came back and said it was a weak diff and gears and that it would be around 900 dollars to replace
Like i said i have a humming noise and vibration coming from the front of the truck.....and they said its the rear diff
Old 02-27-2011, 03:43 PM
Rep:1885
Rear diff noise is typically from failed bearings. Unless they fall apart and cause a bad wear pattern, ring and pinion replacement isn't necessary. I can guarantee that there's no way they could judge the condition of the gears without pulling the cover. You should get a second opinion.
Old 02-27-2011, 06:27 PM
Color: silver
Ok I will have someone else look at it, When I pulled off my rear diff cover to change the fluid I did not notice anything that would lead me to a bad rear diff, I do remember the tech telling his boss he doesnt know where the noise and vibration is coming from then the boss told me replacing the rear diff should get rid of the vibration "SHOULD"
So while im replacing y ball joints and tie rods due to loose steering this week I will pull my front diff cover off and check it out, anything else I should look for that might lead to the vibration Im feeling
MegaCab Roof Racks... experimenting with a FJ Rack. Justin@AACstyle.com Dodge Ram General Discussion 19 02-07-2012 12:03 PM
Power steering rack leak! help! Ramzy 5.7L V8 Specific Topics 3 05-21-2011 12:30 PM
Rack and Pinion on a 2nd gen Ram? carnage Suspension 17 10-17-2010 08:10 PM
2004 1500 5.7 Steering rack problems HOLMES188 Newbie Checkin! 13 08-18-2010 02:52 AM
New rack problem hitmehhh Suspension 1 03-22-2010 06:50 PM
