door speakers not working? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-08-2011, 11:48 PM
ramonator44 ramonator44 is offline
Vehicle: 1997 Dodge Ram
Trim Level: Laramie SLT
Color: red
Rep:22
ramonator44 is on a distinguished road
Unhappy door speakers not working?
ok so i have a 98 regular cab and in the doors there are stock 6x9s and the stock tweeters. the tweeters work fine but the 6x9s are not working im not getting any noise from them not even static. it has an after market sony head unit. i took it out to check the wiring and its all done right. so any help would be appreciated..
1998 Ram Laramie SLT 5.9L
Old 03-09-2011, 11:57 AM
danv802008's Avatar
danv802008 danv802008 is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: ST 4x4
Rep:53
danv802008 will become famous soon enough
You might try pulling the speakers from the door and hooking them up to your home stereo. That might help you figure out if there is a problem with the speakers or a problem with the head unit. With what you are describing i would lean toward it being a problem with the sony head unit, unless you see an obvious problem with the speakers. (Loose wires on the speaker or an erroded gasket around the cone of the speaker.)
Hope that helps...
MODS List: Pro Comp 6" Suspension Lift | Nitto Dune Grapplers 35's | Moto Metal Skull Wheels | Flowmaster 50 Series HD SI/DO | AFE Stage 2 Pro 5 CAI | HyperTech Performance Tuned
Old 03-09-2011, 04:40 PM
Color: red
Rep:22
well i posted this else where as well and they seem to think that the preamp wire from my headunit needs to be hooked up which is what im thinking now to.
Old 03-10-2011, 05:30 PM
Color: red
Rep:22
ok well for anyone else with the same problem i figured it out. when installing an new head unit with the infinity speakers you need to wire the amp remote wire from the head unit to the power antenna wire from the truck.. but then i ran into another problem the speakers only worked when the radio was on not when i had my ipod hooked up so i took it back out and my head unit had a second amp remote wire so i hooked both amp remote wires to the power antenna wire and it now works great.. other then some static when the ipods hooked up... was actually surprised at how much bass these speakers produce.
Auto unlock on exit stoped working Bob2002 Electrical 3 05-09-2013 04:49 PM
Key Fob not working TruckeeT2 2010 Dodge Ram Forum 18 08-21-2011 08:15 PM
Reverse Lights Not Working dschluet 5.2L V8 Specific Topics 4 02-27-2011 02:07 PM
Little audio project I've been working on!! Ryank Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 01-10-2011 12:40 AM
Back up lights not working!!! Need help nickm5 Electrical 1 10-13-2010 10:10 PM
