United Radio
Old 02-26-2011, 11:32 PM
wisconcb's Avatar
wisconcb wisconcb is offline
Vehicle: 2011 Ram 1500 4x4 Big Horn
Color: White Gold
wisconcb is on a distinguished road
Default 35" tires, spacers, and stock wheel lugs?
OK,
Found a set of BFG all terrains in size 325/60R20 that will fit on my factory wheels. I assume I will need 1/4" spacers. Will these spacers work with factory wheels studs, or do i need longer wheel studs? Also, these 1/4" spacers are 5 on 5.5 bolt pattern, but are they hub or lug centric? Im pretty sure my facory wheels are lug centric.
Oh, I already installed the readylift sst 2.5/1.5 leveling kit.
2011 Ram 1500 CC 4x4 Big Horn
www.performancemachinetomah.com
Old 02-27-2011, 12:52 AM
ScatPak07's Avatar
Rep:970
If you are going with a 1/4" spacer then you should be fine with the stock studs. Not sure about the hub or lug centric, but if they are a 5x5.5 then they should fit.
Old 02-28-2011, 12:00 AM
wisconcb's Avatar
Color: White Gold
OK, Im going to give it a shot. I know ARP makes a set of 3" long studs with just about the same diameter knurling, maybe just a hair bigger. I can make them work, mill the length down to 2.5 or so. I would feel safer if I had a lug nuts that were almost bottom out. I think the stock length is 1.9
Wheel Spacers Diesel5182 Dodge Ram Wheels And Tires 4 01-04-2011 03:40 PM
2010 2wd stock 20s. 315/50/20 ?? and Wheel stud question cyberpine Dodge Ram Wheels And Tires 1 11-13-2010 10:37 PM
1" Wheel Spacers? bigedschukar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 10-26-2010 01:12 PM
Stock 20" wheel offset lrn2ski Dodge Ram Wheels And Tires 2 03-02-2010 05:14 PM
