Old 02-27-2011, 10:35 AM
flip16's Avatar
flip16 flip16 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: big horn
flip16 is on a distinguished road
Default 2010 ram
does anyone know the measurements for the factory 20" wheels?...20x?? i think i want to go with a wider wheel to fit my new tires. the tires are 33"x12.5"x20" the tires just dont look right, and does anyone know if this will be a problem? the tires rub at full lock, if i go to a wider wheel will this eliminate the rubbing or do i still need to add 1/4 wheel spacers? THANKS IN ADVANCE for your help.
Old 02-27-2011, 10:52 AM
Don't hold me to it . But from what I've read , there is some issues with the offset of the wheels . They tires will rub the control arms . If you run a wider tire you'll need to make sure the offset is correct . Hopefully someone else with a 4th gen ram will speak up here shortly .
Old 02-27-2011, 10:55 AM
Ramit9990's Avatar
Ramit9990 Ramit9990 is offline
Vehicle: 2011 Dodge Ram
Trim Level: QC Big Horn 4x4x
Ramit9990 is on a distinguished road
The 20's on my 2011 are 8" wide. Tire size is 265/70/20.
Old 02-27-2011, 02:34 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
weird my 2009 have 275/60R20 stock for tires...not to sure about the rim i think its a 20x9, hopefully someone can correct me if im wrong
DODGE the father RAM the daughter!
Old 02-27-2011, 05:24 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
My wheels are 20x9 they're the chrome clad versions. There are also 20x8's from what I read here and elsewhere.
Old 02-27-2011, 06:16 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
chrome clads are 20x9 with either +17mm or +19mm offset.
Old 02-27-2011, 09:22 PM
flip16's Avatar
this is what i do know.. on a 2010 ram big horn with mickey thompson atz LT 305 55 20" tires they will rub at full lock (turn) on the stabilizer bar. i keep hearing that the stock wheels are 8 or 9" wheels.. so i grabbed my tape measure and a straight edge.. i pulled the tape from the inside of the wheel to the face of my wheel and i measured 9"s so for nowI am calling the stock wheel a 20"x9" wheel. also from what i found the wheels have a +19.05mm offset. so if i am correct you would need a rim with a +17mm or so wheel to stop the sway bar rub. does that sound right to you guys?..... more to come
Old 02-27-2011, 09:32 PM
CHVYKLR's Avatar
Rep:252
if you stick with a 9" wheel then the +17 might work. if you go to a wider wheel then you'll have to do some more calculating.
Old 02-27-2011, 10:00 PM
flip16's Avatar
i never knew there was so much involved in tire and wheel selection for our rigs, by the time im done researching either ill be a pro or my head is going to explode!
Old 02-27-2011, 10:03 PM
flip16's Avatar
i am going to buy 20"x9" wheels with a +17mm offset i think that is the route....going to EBAY! im looking at a set of black FUEL rims. for the price they will work just fine
2010 Recall - K08 RamTech Dodge Ram Recalls and TSB's. 6 02-25-2011 03:13 PM
Chrysler Group LLC Reports July 2010 U.S. Sales Increased 5% UN4GTBL Automotive Industry News and Dodge Press Releases 1 08-04-2010 02:28 PM
DVD Player bseifert79 2010 Dodge Ram Forum 5 05-06-2010 07:26 PM
2010 vs 2007 ScatPak07 Dodge Ram General Discussion 20 03-12-2010 03:02 AM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 11:28 AM
