Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
tonneaucovered.com
Old 02-27-2011, 03:18 PM
ckoons22 ckoons22 is offline
Vehicle: 1997 Ram
ckoons22 is on a distinguished road
Default Blowing ATF after Rad Replacement
Hey Guys. I have a 97 ram 1500 5.2L. I had to replace my rad yesterday because it was leaking. So I went and got the spectra from Autozone and ever since replacement I am blowing ATF all over the passenger side of the engine bay. I have gone over the connections and I cant seem to find which one it might be. Has anyone had this problem before? Any ideas of where to really look ? Thanks in advance.
Old 02-27-2011, 03:29 PM
Resident Technician
Rep:1911
Have you checked to see if it's coming from the vent tube? Also check the fluid for signs of coolant. This would indicate the radiator is defective internally.
Old 02-27-2011, 03:30 PM
85fury 85fury is offline
Vehicle: 2008 Dodge Ram 1500
Rep:12
85fury is on a distinguished road
You most likely blew a tranny line, or cross threaded your tranny lines in the rad. Get some brakeclean and clean everything thing off well. Then get some one to start it while you look underneath for the leak.
Old 02-27-2011, 03:33 PM
Vehicle: 1997 Ram
okay I have my one buddy whose a mechanic coming over to help me. Its driving me insane because I never have issues like this haha. Ill go clean the bay quick.
Old 02-27-2011, 03:43 PM
Vehicle: 1997 Ram
@ RamTech- Which one is the vent line? the upper or lower?
Old 02-27-2011, 05:04 PM
Vehicle: 1997 Ram
No what i did was not cheak the new rad to see if all lines were tight heres what happend the line at the top was tight but the nuts on the rad were not so it did not seat on the rad fitting my buddy fixed it all up for me
Thank you guy for all your help
Koons
Replacement Slider (Fob) Keys will not lock? RammD Dodge Ram General Discussion 6 04-08-2011 02:40 PM
Not getting heat after water pump replacement HemiGTX 5.2L V8 Specific Topics 6 01-04-2011 12:51 AM
heater just started blowing cool jacksonbase 5.9L V8 Specific Topics 2 12-08-2010 11:39 AM
Replacement Radiator mjonesjr Heating & Cooling 10 08-04-2010 09:40 AM
2000 Dodge Ram heater not blowing hot jrush78 Heating & Cooling 1 01-16-2009 11:10 PM
