Old 09-23-2011, 06:13 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Default How to remove bezel around tailgate handle
I am trying to remove the bezel around the tailgate handle. How does it come off? 1999 Ram
Old 09-23-2011, 10:01 PM
Okiespaniels's Avatar
Trim Level: Fleet
Rep:47
It pops off once you remove the handle assembly. It's a tight snap, sometimes it helps to bend in the sides slightly. If you have thin enough fingers you can reach behind the bezel and push in on the snap tabs.
Old 09-25-2011, 12:05 AM
sonocativo's Avatar
Color: Electric Blue
Rep:210
I used a small screwdriver on the lower two sides and pry it up.... once the bottom pops out the top just slides down and out as the top 2 tabs are made to create tension so the lower tabs hold it in place. Doesnt take much effort either.
Mike
Old 09-25-2011, 01:37 AM
I'll try that. I tried pulling it off by hand, but couldn't get it. I wanted to make sure there weren't any screws that I couldn't see. Thank you.
Old 09-25-2011, 06:52 PM
sonocativo's Avatar
Rep:210
I can post a pic in a bit so you know what youre dealing with...
Mike
Old 09-25-2011, 07:03 PM
sonocativo's Avatar
Rep:210
The first pic isnt all that good but shows the 4 spring points,
the second pic shows the side view where the bottow 2 are more flexible to keep tension on the top 2, I found it easier to pry the bottom area up and out since the handle kind of restrict the upper area
Mike
How-To: Installing Power Tailgate Lock iRockCrawler Dodge Ram Knowledge Base 67 03-04-2014 04:19 AM
Center Bezel Removal 09-11 moparornocar72 Dodge Ram Knowledge Base 30 07-21-2013 07:05 PM
Heating & Cooling grioux Heating & Cooling 3 01-27-2011 12:53 PM
How to remove and paint radio bezel Lmood Dodge Ram Knowledge Base 20 09-05-2010 09:29 PM
How do you remove the bezel? ramz267 Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 01-02-2010 11:57 AM
