Old 02-27-2011, 06:45 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Default Ground for subs
Alright I cracked and got subs. Everything is wired fine, but, I cannot find a damn ground for my life. It's a 1998 dodge ram, single cab. I've looked everywhere it seems like. Anybody else have any ideas? Let me know where yours is grounded.
Old 02-27-2011, 06:47 PM
Rep:1845
My sub amp is grounded under a seat bolt.
Old 02-27-2011, 06:50 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
I was looking at that, it doesn't look like it would work though. They have a washer thats on the bolt that would maybe make it work. It's stuck on there though. I'll try it out. Thanks man.
Old 02-27-2011, 07:11 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
Well it was the same. Now maybe you could fill me in on this, I'm sure it just means it's not a good ground... The amp has a red light that illuminates and means power protect. When I put it on the areas I think would be good, it shuts off. It's supposed to turn green for power. I don't know whats up.
Old 02-27-2011, 07:16 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Buff off an area exposing bare metal, drill a hole, and use a ground lug like the pic above
Old 02-27-2011, 07:23 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
I've never seen a more complicated bolt lol. Well, is that something i could find at... home depot?
Old 02-27-2011, 07:41 PM
Trim Level: Custom
Rep:1648
You local car audio shop or Best buy
Old 02-28-2011, 09:05 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Did you get em grounded? I used a self tapping screw (made sure it wouldn't hit anything on the back side) but sanded down to bare metal first.
Old 03-01-2011, 02:38 AM
98sst's Avatar
Trim Level: SS/T
Rep:883
Well i did get them grounded. Still didn't work. So, I pulled out a voltmeter and on the side after the fuse, theres 1 volt where there should be 12 going through it. There's no separation in the fuse but it's ghetto looking so i'm going to pick up a new assembly tomorrow.
Old 03-01-2011, 08:58 AM
chithead's Avatar
Rep:2078
Oh ok. Keep us updated man, gotta have some bump in the SS/T!!!
Ground Force 2/3 Drop for 4x4's dustin72 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 02-25-2013 10:24 PM
'10 TRX 2WD More Ground Clearance olegaram 2010 Dodge Ram Forum 4 10-14-2010 06:55 AM
Lowering 2009 Quad with Ground Force Kit HB1098S 2009 Dodge Ram Forum 4 05-14-2010 10:20 PM
95 Ram 5.2 liter - negative ground question pman777 Electrical 14 11-21-2009 10:41 AM
Floating ground Excoastie Dodge Ram General Discussion 2 12-24-2008 11:53 AM
