Old 02-28-2011, 11:08 AM
jaydubbz1019 jaydubbz1019 is offline
Vehicle: 1999 ram 2500
Color: met. red pearl
jaydubbz1019 is on a distinguished road
Send a message via Yahoo to jaydubbz1019
Default help!!!
was driving home and my 1999 2500 started to soundlike a deisel and was idling bad got to a stop and engine just died. started it back up and now sounds ok but i keep getting a weird grinding or chattering sound off and on.the idle every once in awhile drops and the truck boggs down and wants to stall. any suggestions on what would cause this
Old 03-01-2011, 08:08 PM
could this be a plenum gasket problem?
Old 03-01-2011, 09:37 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
my 98 2500 is doing the same thing andd so is my buddys 98 jeep cherokee with the 5.9l in it. we were both told it was a computer problem. computer would need a reflash but in most cases u would need a new one with a reflash from dodge. was told it would cost me $573 for the computer and another 120 for it to be flashed by dodge. cost might vary but thats wat i was told. good luck.
Old 03-01-2011, 10:03 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
Could be any number of things... computer, injectors, fuel pump, plenum gaskets, sensors...
if it was me, i'd see if fuel pressure is right. if it's solid, even when it dies, then i'd check for gasket leaks. if no obvious problem there, i'd start tapping on different injectors and sensors and see if i could cause the problem to show up. if it's running like crap, take a LONG screwdriver and use it to listen to injectors. sometimes you can hear an injector not "firing". after that.. and i'm typing this while sleepy, time to get the scanner and watch what "things" are doing while it's running both good and bad so i can compare.
just remembered... if you hook up a scanner and it stops "talking" to the ECM and the truck is running like crap, 9 out of 10 times, it's the ecm. she's dying a slow death
good luck getting her gtg.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 03-02-2011, 09:26 AM
mattdott mattdott is offline
Vehicle: 1998 dodge ram 4x4
mattdott is on a distinguished road
how often do the ecms go out on these trucks. i have the same truck it runs bad at idle ramdomly. no engine light. previous owner removed cat and no light. code scanner always says pass.
Old 03-02-2011, 10:32 AM
sdram03's Avatar
Rep:52
not very much considering how many of these trucks were sold back then.
have you looked down into the Intake? make sure there is no oil pooling. also, make sure throttle plates aren't carbon covered. may need a good cleaning. also, check the Idle Air Control (IAC) ports and make sure they are clean. any carbon can slow or impede the IAC from doing it's job - which is to control idle.
Old 03-02-2011, 11:24 AM
foolioGrimz foolioGrimz is offline
Vehicle: 1999 dodge ram
Trim Level: 1500
Color: Green
Rep:56
foolioGrimz will become famous soon enough
i ;had an old grand am that sounded like a powerstroke. engine eventually seized up, hopefully its just a computer or other simple problem on urs
mods-Ranch hand Brush guard, superchip tuner, 75 gal transfer tank, 4.10 gears with detroit locker, 305/70-16 BFG mudders, 2" lift, Chrome Edelbrock carb filter with throttle body mod, and a short glasspack.
Old 04-10-2011, 06:25 PM
zxbud zxbud is offline
Vehicle: 1999 Dodge Raam 4x4
Rep:13
zxbud is on a distinguished road
Fixed yet? What happened?
Old 05-22-2011, 11:55 PM
put new plenum gasket in and actually tranny started to act up so got that rebuilt. so farproblem is gone.
