going little higher - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 02-28-2011, 05:45 PM
john99ram1500 john99ram1500 is offline
john99ram1500 is on a distinguished road
Default going little higher
ok heres the deal i have a three inch susp lift as of now my springs are starting to sag in the front is it posable to replace them with 5inch coils without a drop track bar or new control arms truck is 99 1500 sport 4x4
Old 02-28-2011, 09:37 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
If all you have is a 3 inch spacer or springs....absolutely not! Your control arm angles will be too severe and your front differential will be way out of whack with your frame. Caster will be impossible to set and your truck may track doglegged.
Also your steering and track bar angles will be severe, increasing the wear on those components. Your truck will be more suseptable to bump steer.
To do a 5 inch lift properly you should not only have the proper length control arms and track bar setup, but a drop pitman arm and either sway bar drop brackets or longer links.
If you use the factory mounting points for your control arms your ride will still be harsh due to thier angle, but it may be acceptable. Otherwise you'll need psuedo long arms.
Old 03-01-2011, 05:22 PM
sorry didnt give all the info the 3 inch lift i have has the control arms drop pitman just wondering if i need the track bar and if the 3inch lift control arms would be ok to add taller springs
Shaking when breaking at higher speed bigbass19 Suspension 7 03-17-2017 01:04 PM
ac stops blowing at higher rpm???? dirty97ram Heating & Cooling 18 04-10-2014 01:25 PM
Higher amp. alternator str8hemi Electrical 6 01-13-2011 10:42 PM
Gas fill up and engine light then higher rpm's jayhkr LD RAM - General Discussion 6 12-18-2010 12:10 AM
Whistle with higher speed blower motor piercetdi LD RAM - General Discussion 2 12-12-2009 03:48 PM
