Rear End SHOT! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 02-28-2011, 11:26 PM
BOSS 32V BOSS 32V is offline
Vehicle: 2003 Dodge Ram
Rep:13
BOSS 32V is on a distinguished road
Default Rear End SHOT!
Hello all. I'm new here. I have a 2003 Dodge Ram 1500 quad cab 4x4 Hemi. My father recently took the truck into the dealer for an oil change (has 61k) and they noted that the rear pinion seal was leaking. By the time it was parked and on the hoist, it had a 50 cent piece sized puddle under the rear end. They said it would be wise to replace it now, and with the new seal, labor, and fluids ect it would be just north of 200 bucks. Sure, whatever. So they pull the rear cover, and call my Dad into the shop to "have a look at a problem" and it turns out the retainer clip for the differential had broke, and it actually wore into the rear end housing, and carrier bearing cap. We had them button it back up, brought the truck home, and put it on the lift and took the cover back off and started pulling the rear end apart. It wore so far, that it reached the threads of the carrier bearing cap, and being that the part that it mounts to is casted as part of the housing itself, it seems as though the whole rear end is shot. Has anyone heard of this happening? The dealer said the housing is not availble, so it has to be found used. They said they located one with 30k miles and a 30 day warranty, and would be 2,800 plus labor. We're going to put it in ourselves on our lift, but 2,800 seems kind of steep for a used rear end..maybe I'm just nuts? Anywhoo, I can't post a Wanted Ad in the classifieds, so I was wondering if anyone else has ever had this problem, and if so, any tips on finding a used complete rear axle assembley? It has a 3.92 gear.
Old 02-28-2011, 11:59 PM
03Thunderroad 03Thunderroad is offline
Vehicle: 03 Dodge Ram Quad Cab 1500
03Thunderroad is on a distinguished road
I just wanted to let you know that your not alone. I am right now changing the inner pinion bearing over the exact same thing. I also have a 03 Dodge Ram Quad Cab. Mine started making a high pitched noise a couple of weeks ago and the other day I couldn't take it anymore so I decided to tear it down. I have to say its been a pretty big project this far. If there's anything I can do to help just holler.
Old 03-23-2011, 07:29 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2017 ram express quad cab
Trim Level: express
Rep:37
charlieb is on a distinguished road
if ur going to pay that much why not put in a better rear end auburn,detroit,many others between 2600-4000
Old 03-25-2011, 03:20 AM
Rep:2954
you never said which differential, front or rear
the Chrysler 9.25 Corporate differentials have been made for about 20 or 30 years, maybe more
look at this website
http://www.ringpinion.com/DiffSide.a...=1&ModelID=482
another site
http://www.drivetrain.com/parts_cata..._pinioins.html
Old 09-21-2015, 03:20 AM
Ward1998 Ward1998 is offline
Vehicle: 1998 1500 4WD
Trim Level: Lariat
Ward1998 is on a distinguished road
The rear differential is out on my 1998 1500 two years after a fluid change at Jiffy Lube. 75,000 miles, no leaks and the oil level in the rear differential is correct. Now I am curious if Jiffy Lube added any Limited Slip Differential additive like the 4 oz Mopar Limited Slip additive? There is no obvious reason leading to the failure, however, I suspect improper lubricant in the axle. I'm not doing the repair myself and I have not got my truck back from the shop yet.
Old 09-22-2015, 02:20 PM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
Happened to quite a few people with the 3rd gen 9.25. Was JUST starting to happen to mine at 105-110,000 miles when I put the Dana in.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
Old 09-28-2015, 11:33 PM
omarimoe omarimoe is offline
Vehicle: 1997 Dodge ram 1500 SLT
Trim Level: SLT Laramie
Color: silver
Rep:21
omarimoe is on a distinguished road
Dont know where your located but i have a complete rear out of a 04 1500 that i will probably never use. $600 and its yours.
Old 10-01-2015, 01:39 PM
Rep:300
Straight bolt in right there as long as the gear ratios match.
"Big Red"
Old 12-14-2015, 10:44 AM
MandyKandi's Avatar
MandyKandi MandyKandi is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT Lone Star
Color: Atlantic Blue Pearl Coat
MandyKandi is on a distinguished road
My 2005 had a recall on the pinion nut.. it was too short casing the whole rear end and drive shaft to fall, i was going up a big ass mountain when all of this happen... Could not pay the 5000 for a whole new rear end. so i go all used part and BOOM they issued the recall to the public!!! Im trying to get my money back for it now!!!!
2005 DODGE RAM SLT/LONE STAR 1500 QUAD CAB PICKUP
Old 12-14-2015, 10:23 PM
The Ram Man 01 The Ram Man 01 is offline
Vehicle: 2005 Ram 1500 Daytona 4 x 4
Trim Level: Daytona
Color: GoMango Orange
The Ram Man 01 is on a distinguished road
Good luck in getting your money back... Mine locked up & dealer replaced whole unit. Over a year ago. nothing yet.. '05 Ram Daytona
New Rear window with defrost 05DodgeRam2500 LD RAM - General Discussion 17 02-18-2016 02:39 PM
Rear End Questions.... jared1088 Suspension 2 04-18-2011 08:50 PM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 02:13 AM
Pulsing shake from the rear right. wester399 Suspension 9 04-07-2010 09:04 AM
Lowering rear of truck bones64 LD RAM - General Discussion 9 02-09-2010 10:18 AM
