Old 03-01-2011, 08:55 AM
BigHornRam2006's Avatar
BigHornRam2006 BigHornRam2006 is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: SLT Big Horn Edition
Color: Patriot Blue Metallic
BigHornRam2006 is on a distinguished road
Default Front of truck shakes when brakes are hit...
I have had an issue with my '06 Ram shaking in the front when I hit the brakes. The shaking was so bad at one time when I hit the brakes at night I see my headlight beams bouncing up and down on highway signs. So first action I did was change out all four brake rotors and replace with crossed drilled slotted rotors with ceramic pads(February 2011). Now when I hit the brakes it only shakes a tad bit and not as much as it did before. What else could be making the truck shake? The inner and outer tie rod ends have been competely replaced back in September (due to the previous driver not taking care of it). I am also coming up on 60,000 miles. Should there be anything that I need to replace around this time? Please help me out!
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 03-01-2011, 09:55 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
It could be your rotors again because the drilled rotors are not good in my eyes because when they drill them it wrecks the small plates i guess i could call it thats inbetween there fore making it weaker and easier to warp
Old 03-01-2011, 10:01 AM
Rep:1845
Tire imbalance can be amplified by braking. Have a road force balance done to eliminate radial and lateral imbalance. If you have a bad tire, this will identify it.
Old 03-01-2011, 10:28 AM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
There are grease seals that could be leaking lubricant on the rotors which will make the truck shake bad. They are a cheap change and might fix your problem.
Old 03-01-2011, 03:09 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
sounds to me like warped rotors
DODGE the father RAM the daughter!
Old 03-01-2011, 10:47 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
every time ive come across it always been bad rotor cheap ones warp easily from high heat/friction when stopping could be manufacturers defect?? just my expierence so far
Old 03-02-2011, 02:01 PM
It would just seem odd if these new rotors warped that fast. I know they are the same thickness of the factory ones. But the shaking is only coming from the front driver's side.
Dan R.
SGT, US Army
2006 SLT Big Horn
Old 03-02-2011, 05:21 PM
charlieb's Avatar
Rep:31
brake checkups are free around these parts midas/mr.transmission let a pro take a quick look at it, dont have to let them do the work
Old 03-03-2011, 12:32 AM
nitro1965 nitro1965 is offline
Vehicle: 2013 Ram Express 1500 Quad Cab
Trim Level: exspress
Color: cherry pearl red
Rep:27
nitro1965 is on a distinguished road
i had the same problem and it turned out to be a broken steel belt on tire. i replaced tire and the shake went away as well as the wobble in steering wheel,
Old 03-03-2011, 08:55 AM
3rdgenluder 3rdgenluder is offline
Vehicle: 2006 ram 1500
Trim Level: slt quad cab sport
Color: RED
3rdgenluder is on a distinguished road
what is the condition of your tires? have you had your alighnment done recently?
bad alighnment can cause poor tire wear and then the poor tire condition can affect breaking and acceleration...one effect is bad vibrations
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 07:14 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
04 dodge ram front differential noise timhorton Newbie Checkin! 10 09-24-2010 11:48 PM
Love My Truck, Hate It's Vibration MriDude 2010 Dodge Ram Forum 36 07-27-2010 12:14 AM
Truck shakes a bit when I put it in 4 wheel drive?? ThatGuy321 5.7L V8 Specific Topics 2 06-09-2010 04:38 AM
